CountryBoy
- Joined
- Feb 7, 2001
- Location
- Strasburg, VA, USA
- TDI
- 2009 VW Jetta SportWagen TDI DSG, 2002 Jetta GLS TDI 5-Speed
Was looking through a clutch manufacturer website, Spec Clutches, and found that they have clutches for TDI engine VW's. It lists both a 220mm Luk size OEM clutch replacement and a 228mm Sachs size OEM clutch replacement. The holding capacity of Stage 1 is 330 torque where as stage 4 is 460. Not sure if this is ft-lbs but I would assume so. Anyone have any thoughts, experiences, advice on these systems?
