alex_tdi
Hi,
I've noticed a swoosh swoosh sound coming from the serpentine belt / timing belt area during cold starts in the morning.
My old serpentine belt had frayed on one of the edges so I replaced it with a new one. The swoosh swoosh sound was reduced but still noticeable.
I replaced the idler roller, although the old one felt smooth.
I checked the alternator pulley (I jammed a screw driver and found out it was a solid one) and it also turned smoothly.
The last thing is the power steering pulley. It seems to have some play (about 1 or 2 mm) in terms of how far out or close it is to the pump.
Is that normal?
or should I start looking at replacing the pulley/pump? The bolts seemed to be on nice and tight, are those throw away bolts.
Thanks.
Alex
Is that normal?
Thanks.
Alex
