yogamatt
This past Monday I went to start my car to go to work it sputtered like it wasn't getting fuel, but then ran fine after a few seconds. Same thing happened hours later when I went to lunch. Then again when I was going home. A few hours later I drove it about 20 minutes and it sat in the parking for about 90 minutes. This time the car sputtered, ran for about five seconds, and then died. I never could get it to start after that. The engine would crank, but that was it. The next day I towed it to the dealer 45 miles away because I thought it could be a problem with the HPFP. It started right up for them, and they suggested replacing the exhaust flap on the engine. He said that was seized up, and could be causing the problem. They checked the fuel filter, and there were no metal shavings in it. I picked it up on Wednesday, drove it maybe 12 minutes down the road, stopped to eat, and then drove it across the road where it sat for about 75 minutes. When I went to start it this time it did the same thing. Had to have it towed back to the dealer later that day. Of course the next morning it starts right up for them. I suggested that it's only happening after the engine has warmed up and left to sit for a while. They were able to duplicate the problem yesterday, and have been working with VW Tech Support to diagnose it. Their suggestion to the dealer was it is in the fuel system, and they narrowed it down to faulty injectors or a check valve not closing. They said the injectors would throw a code if they were bad, so they don't believe the problem is there. They told me the valve is not closing to build up pressure for the engine to start, and it's letting fuel flow back in to the tank. After the car gets started it runs fine. So, that is their next part to replace. Does this seem like the probable cause? My searches for a faulty fuel check valve only seemed to results for the car parked on an incline.
http://youtu.be/wEBpdblovDY
