philb
hopefully somone will help on this one
issue ...white smoke at idle and if it ticks over for a couple of mins....then throttle is blipped a cloud of it appears white ..
does this with turbo pipe removed as well
checked timing i think vcds lite group 4 idle 5.5degrees btdc so i dont think its timing
vcds at tickover group 1 861rpm 4.2mgstr 1.6v..79 degrees
group 8 861 rpm 0 mgstr 30.6mgstr 24.3 mgstr
this group 8 readings seem very odd all change when revved up....
if i can figure a way to post pics on her e i will show u ..
also just gave about 3/4 litre of water spray down inlet to try and clear and crud out
anyone help me in this one
more data vcds at 2037 rpm
group 1 5.8mgstr 1.56 v 79 degrees
group 4 2.4 atdc 2.4 atdc
group 8 5.8 mgstr 42 mgstr 26mgstr
thanks
thanks
