loco_unoTDI
About a week ago the Jetta started taking an extended crank time and puffing out lots of white smoke that smelled a bit like diesel. The engine would run quite rough, shake the car as I have the ECS dogbone mount, for almost a minute. Once warmed up things seem to be fine until giving the car heavy throttle and rpms are above 3400. Power just stops and will not rev.
I have unplugged the CTS sensor for full glow plug time and that changed nothing. The fuel filter and thermostatic tee are new. The injection pump a new unit about 12k miles ago. The timing belt was done by a reputable shop 12K miles ago. The car has 162k miles and before I purchased the car 15k miles ago the unkown previous owner had run WVO in the car (unkown length of time it was used).
The Vag-Com pulled a code P0252 that came on the other morning when it was 40* and the car stalled twice upon starting and running for a few seconds.
Here is the data I captured on VCDS:
I am thinking a leaky injector and some diesel purging is in order. What do you GURU's think?
I just got the Vag-com and am learning to use it. Let me know if you need anything else.
Travis
Travis
