ro.sniper
I would like to test this off-road..
I believe my EGR cooler is leaking which is causing a slight stumble at 1800-2000 rpm...
What do I unplug to test?
I believe I have to unplug the vacuum hose from the egr cooler valve?? Is there another plug that I have to remove? Does the test only work if I put block off plates?
If someone could provide me some detailed info on the procedure I would greatly appreciate it.
Cheers,
Raz
Cheers,
Raz
