Thank you for the referral, Ol'Rattler. I appreciate it.
I have a problem with this 'block off plate' fix. You may have blocked off the exhaust gasses from the manifold to EGR pipe, but you have done nothing to stop the boost leak coming from the other way. You will still leak boost through both the EGR to manifold pipe and the leaking seal from on the EGR cooler's butterfly valve, which is the main culprit. We know that a major portion of the boost leak will still happen, which is degrading your engine performance. BTW: The circles in Fouillard's pictures, showing the areas of exhaust gas leaks are 1/2 right. The Bellow on the manifold pipe are broken, but the other circle, showing the vacuum diaphragm, is incorrect. The exhaust gasses are leaking on the butterfly valve, directly under the exhaust pipe. So, Fouillard, I'm thinking you are wrong.
I am also going to guess that the reason the exhaust to EGR pipe broke is because not all the screws connecting the EGR cooler to the back of the block are tight. If the EGR cooler is shaking, that is the usual reason the pipe's bellows on one side or the other, fail.
We can get a replacement exhaust pipe and make a repair to the EGR cooler and that fixes the problem and restores the operation of the engine. The reason we make the EGR cooler operate; it heats the antifreeze, helping your engine to warm up more efficiently. We think that is a good idea in Denver, as it can get very cold. You'll need the EGR's ability to heat the engine's coolant.
We keep a steady supply of our repaired EGR coolers in stock, with the proper installation parts. We also buy back your broken EGR cooler, if it is a repairable core.
Questions? Feel free to call.
