jdawgster
This is my first post here on these forums.
I recently purchased a 03 jetta 1.9 tdi with the alh engine.
Was told it has malhone stage 2 tune? And its deleted, but the egr cooler is still in the car? The last owner was lazy and didnt remove it so thats on my list.
When i got it it was lowered, and since i live in new york and snow/pot holes are a thing. I got stock suspension and new e-break cables so i can idle it im the driveway in the morning . I noticed it was hard to start so i swapped out the glow plugs . Still starts a bit rough and i keep blowing a 50a metal fuse above the battery. (Pic included) im not sure if thats the fuse for the glowplugs though .
I did an oil change and the glow plugs and now the boost is no longer staying at 18 psi like it did when i first got the car ... now it likes to sit at 30psi (about 2 bar) is this bad? Or is the turbo just spinning better now that it has clean oil? It has went i to limp mode when accelerating in 4th gear. But didnt throw any codes. I have a vagcom and vcds.
I have a video of the boost and a few pics... i found some cut wires in a harness thats next to the glow plug harness does anyone know what these could be? Or have a good wiring diagram?
Thanks in advance!
http://imgur.com/gallery/N982OpV
https://youtu.be/egKx40sJXnk
Thanks in advance!
