Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old December 3rd, 2018, 09:31   #1
alireza57
TDI(s): touran
Default Oil leak
Hi don't know if I post it in right place as I'm new here
Been for mot 2days ago and find out the oil on the back of the engine where the turbo fitted what could it be turbo seal or head gasket or valve cover gasket
Advice pls
Sent from my CLT-L09 using Tapatalk
alireza57 is offline   Reply With Quote
Old December 11th, 2018, 06:11   #2
uzi_cupra
Most likely the back of the valve cover, the rubber gasket can give way, or it could be the breather hose going into the turbo intake pipe from the valve cover which may be leaking - neither are a a major issue, just annoying.
'04 Ibiza Cupra Tdi - GTB2260vk stage ∞
uzi_cupra is offline   Reply With Quote
Old December 11th, 2018, 06:58   #3
Tdijarhead
Likely the valve cover.
Will that leak fail you for a MOT?
I assume MOT is like the inspection we have here in the states.
Tdijarhead is online now   Reply With Quote
Old December 21st, 2018, 12:40   #4
alireza57
TDI(s): touran
No it hasn't fail the mot the guy didn't even noticed it but I did and took some pic if he does notice it goes as an advisery in mot certificate lol
Old December 21st, 2018, 17:19   #5
Tdijarhead
So an advisory is similar to say a warning? It will not cause a fail but is written into your MOT? Warning , you have an oil leak!
What about a leaking shock?
Or brake pads worn down to barely there?
Old December 22nd, 2018, 03:26   #6
alireza57
TDI(s): touran
Shock absorber and break and light and screen wiper are highest reason to fail the mot if they not in working order so its best to make sure they are working fine b4 taking the car for mot
Engine oil leak is something u can can drive the car without any harm calls to other road user as long as not really really bad leak
But if something witch it can't sort out on mot garage u get so many days to fix the car and get it check again for free mot
Old Yesterday, 00:25   #7
Ol'Rattler
Ol'Rattler's Avatar
If the head just below the valve cover is wet on the back side of the engine, try snugging your valve cover bolts.
On my 2006 the size is a Torx-30. I would suggest getting a Torx driver without a removable bit. You wouldn't want to loose a Torx bit behind the engine.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Fuel Leak and Oil Leak Problems charlieruu TDI 101 2 September 20th, 2016 15:32
Oil leak. Coolant leak. Injection pump leak. Chris_TDI_98 VW MKIII-A3/B4 TDIs 3 April 23rd, 2016 12:00
Power Steering leak, and oil leak questions Spiked1Z VW MKIII-A3/B4 TDIs 7 January 30th, 2014 20:55
Adding UV leak detector dye to oil to find leak srponies TDI 101 16 July 4th, 2012 05:18
'97 Jetta TDI Oil Leak at Oil Filter Engine Mount? bassmun TDI 101 0 November 14th, 2011 19:48
Page generated in 0.13820 seconds with 12 queries
[Output: 80.28 Kb. compressed to 69.93 Kb. by saving 10.34 Kb. (12.88%)]
