prblue
I recently discovered I need a camshaft mounting frame VW tool T10262 to remove the bearing frame from the cylinder head of my tdi 2.0 16v BKD engine. Unfortunately the tool that consists of 4 pieces of steel square with some screw holes costs way more than it should for what it is in my humble opinion.
This is the tool:
More pictures:
To me this tool looks like it simply screws into 10 cover mounting holes, and using four screws on the side it pushes the bearing frame off the cylinder head. Unfortunately the pictures are not great so I can't be 100% sure this is how it works.
This is how the bearing frame is installed on the cylinder head:
It seems that those 4 bolts on the side of the tool push against the cylinder head bolts - those that use the bolt-in-bolt design they describe above.
If yes, I can easily make this tool. Could someone please confirm if I understand its function correctly, please?
This is the tool:
More pictures:
