Connector
Help. I cut the wrong 4 prong plug when replacing glow plug harness. There was a 4 prong connector under the the power steering resevoir and battery shelf. It match and fit. I did not pay attention and cut the wrong 4 wire harness. Does any one know what each of these four wires goes too. The plug is jsut like the glow plug harness and it is closer to the motor than the glow plug harness plug. Thanks, Kevin
Here is my advice:
Go to a local salvage yard and find any A-4 Jetta.
Remove the harness channel cover and cut the connector you need including as much as the harness as you can get.
Go to a local VW dealership and buy the butt connectors for the size wire you have (take your slavaged connector with you).
Do not try to do a BS hack-job when you install this connector.
These cars are sensitive to circut impeadeance and if you try the old "tape it till it choaks" junk you'll have problems, a lot of problems.
If you do not know how to splice in a connector correctly then pay someone else (who knows what they are doing) to do it for you.
