dinoless
Sitting here on vacation 400 miles from home. Went out to the 05 Passat this morning and notice a puddle of fluid under it. Slither under and find it's leaking from the transmission. 8mm drain plug is loose, I've got about 2 quarts on the ground.
Can't find a local VW dealer, local parts house of course does not have v050 or v70 fluid. Valvoline book says to use MaxLife Dex/Merc. Can I mix this in (about 2 quarts I think) and get me home or is what is likely OEM tranny fluid and this MaxLife gonna argue and bugger up my transmission on the road home tomorow? If it will get me home, I'll order up the right stuff and do a full fluid change.
Second...where do you put fluid in? I find NO dipstick...
