FordTech2004
Hello,
I have recently acquired (or will be acquiring this weekend) a 2002 Jetta TDI. Long story short the previous owner says the car is overheating under load (up hill, under hard accel) and blowing coolant out of the degas bottle. The P.O suspected a head gasket issue and replaced the gasket however the car is doing the same thing. By stalking the P.Os post history I was able to figure out that the water pump was already replaced with one that has a metal impeller, the rad and heater core were flushed and determined to be ok, also replaced the coolant temp sensor and possibly the t-stat. They also said the fans tested good. Now I will be going back over all these areas and checking for myself, not because I don't trust the P.O but because that's just how I am. However if I am going to make an assumption I am guessing a warped head. Now the P.O did state they did not detect a warp with a straightedge when doing the head gasket. My question is, has anyone seen one of these 1.9 heads crack, or even better, has anyone seen a crack in the block?
Furthermore, does anyone have a good head they would like to part with?
Thanks for any input!
