pyro7890
ben of aj's tdi diagnosed a bad injection pump after we had a no start after inital timing belt change. so... i got a new pump from a trusted area bosch dealer(if anyone else thinks of doing this just send it to dfis). then i put everything back to gether and it did idle for as long as i would let it but it would not rev also lots of white smoke. so i took it to the Wichita gtg and we adjusted the ip timing still ran terribly. so i was just ready to have the car running again ( it has been out of commision for 6 plus months) so i drove to nevada missouri(4 hour drive) and had ben work on it( he is a great mechanic by the way) and he checked everything he could think of and got it a little better but still ran poorly. he ended up calling frank irving and between the two of them they came up with the company gave me a bad reman pump that or the very unlikely possiblitly of the ecu.
so i called the place and told them of my woes and they told me they wanted to take a look at it which i am sure i will have to pay for. but he told me if i wanted to save my own time i should do a compression test he is almost positive that we timed it wrong and that a piston hit a valve and i think they are full of it and so does ben. does anyone have any ideas or has anyone had issues with reman bosch pumps? thanks
i would love to keep this car but i am about ready to take it and blow it up
