1999 Beetle 5 speed. Recently started overheating on long pulls over mountain passes. It got up to 220, so I pulled over. By the time I got pulled over and stopped, it reached 240. Temps are read by an Ultra Gauge. Let it sit and idle for a few minutes and it cooled off. I smelled antifreeze, so I popped the hood and it had pushed some antifreeze out of the bottle. Made it the rest of the way to my destination by babying it on the big hills. First thought was thermostat was stuck, so removed thermostat for the drive back home. Still overheated on the way home. First 2 hills it got to about 210 at the top. Biggest hill it got to 220 then 240 again. Compression test shows 500-480-430-430. Has metal water pump impeller that has been checked.
Timing belt, tensioner, idlers, and water pump replaced 20k miles/ 11 months ago.
Radiator replaced 70k miles/ 3 years ago
EGR cooler removed and bypassed 3-4 years ago.
Without the thermostat it would run about 120 driving 75. As soon as you start pulling a big hill it would climb fast. Once out of the mountains it runs normal. Any ideas where to go next?
Sorry for the long post, thanks for the help.
