Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old December 2nd, 2019, 15:49   #1
benchote13
TDI(s): Jetta, 2000
Default Front Wheel Bearing R&R Tool
I need to replace a front wheel bearing. Does anyone have a Front Wheel Bearing R&R Tool I can borrow by any chance or know where to get one locally?
Canadian Tire no longer sells these and they don't have it in their tool loan program either, Princess Auto also doesn't sell them. They're available on Amazon but I thought I'd try this route first. Thanks!
benchote13 is offline   Reply With Quote
Old December 3rd, 2019, 12:33   #2
P2B
P2B's Avatar
Checked Part Source? They still had it for loan last time I did a front wheel bearing a couple of years ago.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old December 5th, 2019, 09:40   #3
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
What Simon said. As far as I know, Can Tire stopped their loan a tool program several years ago, but Part Source still did it. That's where I got the tool when I did mine.
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old December 5th, 2019, 10:49   #4
amit9
amit9's Avatar
Somewhat related, I need to replace my front wheel bearing too. I need to get a front wheel alignment as well. The alignment has been off from before the wheel bearing went bad.
If I get the front wheel bearing replaced now, the concern is that with the alignment being off, hope that does not affect the new wheel bearing till I get the alignment done a few months later, like in April? I think that the bad alignment may have contributed to the bearing going bad, so just wondering that after replacing the bearing, I need the alignment done right away or it can wait for a few months.
Thanks.
2003 GLS "SilverJet" TDI, Zerostart 1000W, Defender-Tech skidplate version 2
amit9 is offline   Reply With Quote
Old December 5th, 2019, 12:23   #5
P2B
P2B's Avatar
If your alignment was off enough to reduce wheel bearing life, I reckon you'd be replacing front tires as often as you fill the tank.
Simon
Old December 5th, 2019, 12:42   #6
amit9
amit9's Avatar
Simon
Simon, the front tires are somewhat worn out on the inside tread, not too bad though. So I gather from your note that I can wait a bit for the alignment after getting a new front wheel bearing, correct? The plan is to get the wheel bearing done now as the droning noise is too irritating. And then get new tires in Spring followed with an alignment right away.
Old December 6th, 2019, 17:12   #7
graeme20
graeme20's Avatar
TDI(s): 2013 GSW
Fuel Economy: 5.2 l/100 on the ALH, about 10 on the VR.
I have one you’re welcome to use. Located in brooklin. Graeme
graeme20 is offline   Reply With Quote
Old December 6th, 2019, 21:16   #8
benchote13
TDI(s): Jetta, 2000
Thank you! I will send you a PM!
To the others thanks for your replies, but no Part Source does not have them anymore, it was the first place I tried. They have a pretty limited amount of tools that are part of their current loan program.
Old December 7th, 2019, 06:12   #9
mrrhtuner
mrrhtuner's Avatar
Amazon, the tool is pretty cheap
mrrhtuner is offline   Reply With Quote
Looking to borrow the front wheel bearing R&R tool rrobbiiee Ontario 7 July 5th, 2012 21:42
Front wheel bearing tool Q... Motor7 TDI 101 17 July 4th, 2008 14:49
Front wheel bearing tool??? Doc_Oc Ontario 13 May 16th, 2008 13:40
front wheel bearing tool former chevy man VW MKIV-A4 TDIs (VE and PD) 11 January 22nd, 2007 19:43
Front Wheel Bearing Tool LanduytG VW MKIII-A3/B4 TDIs 14 September 27th, 2006 10:03
Page generated in 0.16979 seconds with 12 queries
[Output: 93.08 Kb. compressed to 79.45 Kb. by saving 13.63 Kb. (14.65%)]
