Hi guys ive a 2011 jetta. Ive a bit of water in the passenger side footwell.
The rain tray/scuttle panel is clear and the door seals seem good. Is there anything else to check..
defiantly sunroof drain. VW finally put in their maintenance program to blow out the drains. The factory has an amazing tool for it but doesn't give it to dealers for some reason. Huge problem with VW and Audi's
