Brakes - Rotors & Pads
Benedict
Ontario, Canada
2015 Sportwagen
Hi, I recently picked up a 2015 Sportwagen TDI Highline/GT/SEL. I've been looking online for the things I will need in the near future (ie. brake rotors, pads, filters, etc). For Brakes I've been looking mostly at Bosch QuietCast and Brembo OE, but haven't had success finding the part numbers for my car. Below is what I have found so far, if I have made any mistakes please let me know.
What I haven't found so far is the part numbers for Bosch front pads, or Brembo front/rear pads. If anyone knows them it would be appreciated.
Also, does anyone know if the MK7 Sportwagen front/rear brakes are the same as the MK7 golf? If they are I'd probably have an easier time finding things.
Front Rotor - Brembo - 288mm
1K0615301T - OE
09914511 - MFG
1K0615301T - OE
09.9145.11 - MFG
Front Rotor - Bosch QuietCast - 288mm
53011411 - MFG
Front Pads - VW OEM
5QD698151 - OEM
2568301 - MFG
Rear Rotor - Brembo - 272mm
1K0615601AA - OE
08.B413.11 - MFG
Rear Rotor - Bosch QuietCast - 272mm
14011491 - MFG
Rear Pads - Bosch QuietCast
BP340A - MFG
Rear Pads - Bosch Blue Disc
BE340H - MFG
BE340 - MFG
Mike_04GolfTDI
Richmond, BC, Canada
Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
On my 2004 Golf, the original brakes lasted 8 years. I wouldn't be too worried about buying new brakes immediately.
laminated
Canada
15 Sportwagen
I think they are the same as the B7 passat,,I bought ceramic pads so no dust, rear pads are the same as the Mk4 is what I was told
Benedict
Ontario, Canada
2015 Sportwagen
Hi, thanks for the replies. Im sure the brakes will last a long time too, the oem rotors and pads are quite good for braking. Im just the type that likes to write down notes and have spares so they are sitting at home closer to when i will change them. Cheers
