Kashwashwa
Ok, so my 98 Jetta TDI which I purchased 4 months ago has been sitting in the driveway. I just licensed it, and was going to start driving it starting today.
The only time I've driven it was the 200kms to my house from where I purchased it, and that was in the summer.
Anyway, I charged the battery overnight, and the car started fine. 1st problem - check engine light came on. I'll get my friend to check it out.
2nd and more immediately major problem - it wont get in or out of gear...
We're talking like 0 degrees fahrenheit, or -16 C or so, it's not THAT cold.
I tried to put it in reverse and it seemed REALLY tough, but sometimes reverse is, so I end up shoving it in gear, but barely. It felt quite weird backing up - like the clutch wasn't doing a lot, becuase the drive would keep going a bit while the clutch was in, it wouldn't take all power away like it should.
Then I realize while I'm in the street, this thing is NOT coming out of reverse... I shut the car off, and mess with the shifter for about 10 minutes, thought I might brake the thing , but it eventually finally came out...
While the car was off, I could put it in the gears, but while it was on, I couldn't.
Is my clutch shot??? ....
Could it have something to do with the transmission fluid, and sitting for that long?
