Hello all,
Been lurking here mostly for a few years and decided to trade my 2009 JSW for a 2008 Subaru Outback. The VW had 45,000 miles on it and was a very good running car. The problem was that the closer I was getting to the 60,000 mile power train warranty expiration the more I worried about having to deal with the HPFP failing, not willing to have to pay for a failure that could be relatively easy to resolve for VW if they were paying attention.
I am of the belief that VW could do one of two things to make the issue a non issue or a low cost repair.
1- Step up and replace the pump with a properly designed and engineered pump. Siemens for example. OR,
2- Install a filter "after" all of the fuel pumps and before the injectors, this could be done on all new MY cars from the factory and, the filter could be retro fitted to the existing cars currently on the road. A filter exists that can more than handle the pressure and the particles that the pump sheds, when/if the pump fails, replace the pump, clean out the fuel line to the filter, replace filter element, start car and go.
If these fuel systems are going to be so expensive than all car companies should be protecting the parts and the consumer from such a failure.
No person should be on the hook for a $8-10,000.00 single item repair on a vehical. Until VW gets their st together I'll be driving a soobie.
Dan
Dan
