HopefulFred
I cranked my new 2006 (A4 of course) Golf this Monday to come home from work and the immobilizer light started flashing as soon as the engine started. Since the engine didn't shut off, I figured I would just drive home and try the other key. I restarted the car on the way home after I killed the engine comming too quickly off the clutch (accelerator response is just not like I have been used to). When I restarted it, the light went away.
This afternoon on the way home, the light came on again, just like yesterday. This time I saw the light go off as I set the parking brake to drop off my carpool buddy. When I stepped back on the brake and clutch it came back on. Fiddling with it at a stop light, I managed several times to turn it off by setting the parking brake. I reactivated the light as I stepped back on the clutch and brake pedals to pull away from a stop. I haven't been able to reliably activate the blinking light, but I have been able to reliably deactivate it.
I can't see why the parking brake would have anything to do with the immobilizer, but it seesm to. Can that light indicate anything other than the ECU not recognizing the code in the key?
Bummer about having weird electrical lights on only day three of ownership. I don't have a VAG-com yet, but I don't know if there would be a code of any kind anyway. I'd appreciate any insight you guys have.
