rotarykid
- Joined
- Apr 27, 2003
- TDI
- 1997 Passat TDI White,99.5 Blue Jetta TDI
Your post of a mazda 3 seeing 40 mpgs on your trip, manual trans or automatic?? ARe those pen & paper numbers are ecu generated numbers??
Your car is closer to Polo, Corolla, Sentra, Civic than the current Jetta, Golf, NB, or the current gasoline or coming 6. As I have said over & over the cars in your class can easily hit that 40 mpg mark with the right engine and transmission combo. Where it gets tricky is in the larger class current diesel offerings head to head with the gasoline powered counterparts.....
And how does that 3 compare in size, ride and driving experience compared to the coming 6 diesel or the current diesel Jetta/Golf class offerings sold here today?? The 3 is a much smaller and lighter platform so higher mpgs are possible with the right engine & transmission under the hood.....
And on what is possible with gasoline power, with lean burn tech similar to diesel numbers can be seen but these engines "require" ULSG and PM filters to pass emissions tests....
