Old May 14th, 2018, 15:41   #1
distra45
Default 2010 sportwagen A/C help
I have a 2010 Jetta Sportwagen and the A/C quit a couple weeks ago. I have the the VCDS software and I need some trouble shooting advice. The A/C control valve has just been replaced, but the system will still not come on and blow cold air. I can activate fans with the software, but the pressing the A.C. button does not start the small fan on the passenger side. No fault codes that I can see...or maybe I'm not looking in the right spot. Any troubleshooting help would be appreciated.
distra45 is offline   Reply With Quote
Old May 14th, 2018, 17:50   #2
cliballe
TDI(s): 2010 Jetta
Fuel Economy: 40 mpg
In VCDS can you go into the Auto HVAC Module, Advanced measuring values and look at a few locations? Check 007 Center Vent Temperature, 008 Compressor Current, 009 Compressor Load, 016 Coolant Fan Activation, 024 Engine Speed, 061 Refrigerant Pressure and post a screenshot of those results.
cliballe is online now   Reply With Quote
Old May 14th, 2018, 20:30   #3
distra45
Engine Speed 800/min
Refrigerant pressure-MUX 5.6 bar
Compressor current: specified value 0.820 A
Compressor load 1.6Nm
Coolant fan activation:actual value 9.6%
Coolant fan activation: specified value 0.0%
Center vent temp 29.7C
08-Auto HVAC -- Status: Sporadic communication error 1000
https://photos.app.goo.gl/sOe7vT7fjGLHiF8w1
Old May 14th, 2018, 21:38   #4
cliballe
TDI(s): 2010 Jetta
Had you just started the car, or did you run it a while before taking those readings? The refrigerant pressure and fan speed isn't adding up for me.
When I had an issue with my RCV the pressures were higher than yours (~12 bar) and the fan still worked too (~50-70%). After the compressor was replaced the refrigerant pressures went up to ~17 bar at idle.
Old May 15th, 2018, 04:20   #5
distra45
It had been running about 10-15 min when I took these readings. The compressor wheel is spinning, but the center bolt and flange are not. The coolant fans turn on with the output tests.
Old May 15th, 2018, 13:29   #6
distra45
Is it time to replace the compressor?
Old May 15th, 2018, 21:20   #7
cliballe
TDI(s): 2010 Jetta
So I'm guessing the shear plate feature of the compressor hub was tripped? Are you able to turn the center part of the compressor hub by hand? If not I'd say your compressor has seized internally.
Old May 15th, 2018, 21:57   #8
Goatfish
TDI(s): 2011 Jetta
It could just be the shear plate that needs replacing I used this kit on my Delphi unit and it saved me about a grand since VW wanted me to order a brand new compressor . By the sounds of what you described above this may be what you need .
https://www.youtube.com/watch?v=kkJtjgLTa8M
Goatfish is offline   Reply With Quote
Old May 21st, 2018, 13:17   #9
distra45
I replaced the compressor this weekend and checked for leaks. System held a vacuum so I recharged it. Compressor runs, fans run, cold air is coming out of the vents. Still not sure why the compressor went, but I hope this one last a few years.
Ecu swap. 2010 Jetta manual into my 2010 sportwagen dsg Eliminator SS VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 September 3rd, 2016 10:44
Page generated in 0.16210 seconds with 11 queries
[Output: 83.83 Kb. compressed to 71.27 Kb. by saving 12.56 Kb. (14.98%)]
