Mike_04GolfTDI
- Joined
- Nov 19, 2003
- Location
- Richmond, BC, Canada
- TDI
- Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
I recently put a new head on my engine after a timing belt failure. (http://forums.tdiclub.com/showthread.php?t=488492)
Initially, the engine sounded "fine" but I'm sure I hear a knocking that isn't supposed to be there. It gets slightly worse when the engine is fully warmed up.
Have a listen:
https://www.youtube.com/watch?v=oqaWCMJP5Aw
I think this is perhaps something in the connecting rods. Wrist-pin or maybe big end bearings.
I suppose the only way I will know for sure is to pull the head off again and remove the pistons. I wouldn't be afraid of putting new connecting rod bearings in it, if that's all it needed, but if the bearing journals on the crank are damaged, then I'd be starting to question whether it's worth the trouble.
The car drives fine, so I'm kind of leaning towards just driving it until it beats itself apart, while I keep an eye out for a 2004-2006 Jetta Wagon.
Have a listen:
