Old January 3rd, 2017, 07:14   #1
jaberoo
jaberoo's Avatar
Default Third Broken Spring!
I've been driving for over 60 years with more cars than I can remember, and over 200K miles in some, and I had never had a broken spring until my 2010 TDI JSW which has now broken it's 3rd spring, just weeks before my buyback date. The first two were rear springs, this one is the left strut.
Surely this should be a recall matter.
What do members think?
jaberoo
15 Passat SEL, Autobahn blindspot mirror
jaberoo is offline   Reply With Quote
Old January 3rd, 2017, 08:05   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yep, it happens. See it on a LOT of Ford products, too. A few on some ChryCo products. Also quite a few MB products. I wonder if the supplier is the same.
If every car manufacturer recalled every last thing that has a pattern failure, then there would not be many cars left on the road.
oilhammer
www.cardocautomotive.com
Old January 3rd, 2017, 08:12   #3
meerschm
meerschm's Avatar
recall is for a reason, not just because it will fail and need repair.
if the spring failure made the wheel fall off, or the tire rub on the fender, it would be a different matter.
for the most part, seems there are more subtle effects from the failed springs.
when my rear snapped, the only hint was a creak when I went over a shallow dip at the end of my driveway.
how did you know the front spring broke?
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old January 3rd, 2017, 12:56   #4
redbarron55
I had an Isuzu Trooper that broke left rear spring several times.
When I fixed the driveway entrance so there was not a bump at the entrance the springs quit breaking
redbarron55 is offline   Reply With Quote
Old January 3rd, 2017, 15:12   #5
jaberoo
jaberoo's Avatar
I didn't know I had two broken rear springs until the dealer service told me and charged me $500.
But when the front spring went, there was a loud clang when turning hard left or hard right. The mechanic (not the dealer) immediately suspected a strut and sure enough when he put it up on the hoist, it was there plain to see.
The bummer is, it effectively decreases my buyback
jaberoo
Old January 3rd, 2017, 15:33   #6
meerschm
meerschm's Avatar
You probably could drive it to the buy back as-is.
Mike
Old January 3rd, 2017, 18:30   #7
redbarron55
yes
Old January 3rd, 2017, 23:03   #8
2011tdiproject
TDI(s): 2011 Golf
I'd sure be curious to see a couple pictures of those broken springs. I've never seen a coil spring break, only leafs on pickups, & those were overloaded & abused.
2011tdiproject is offline   Reply With Quote
Old January 3rd, 2017, 23:39   #9
gmcjetpilot
gmcjetpilot's Avatar
Three things:
1) Yep so many springs does seem excessive, but it's not uncommon
for VW springs to fail apparently, although I never had broke springs
in other cars (or my VW for that matter) in over 38 years.
2) Snow, salt doesn't help. You get corrosion, pitting, then fatigue crack.
3) Don't fix it, sell it back as is. Just be careful and drive conservatively.
It could (will likely) affect handling and stopping to some extent.
I recently replaced my shocks and struts myself. I did not buy new springs,
and did not want aftermarket lower springs. I was nervous taking it apart,
I'd find broken springs and have a show stopper. Springs near perfect, with
the factory finish is excellent shape. There was a little rust at the bottom
of rear springs where they sit in lower control arm cup. Typically they crack
down there in the first loop from what I have seen online.
Cost to replace rear springs should not be $500. It is about an hour of labor,
total both sides. The cost for a pair of springs is $120. $250 should have done
it, $300 even, but $500 is a little steep.
Struts are going to be closer to $500 to replace springs. However if a strut spring
breaks change the spring and struts out both sides as well (for a car you are keeping).
gmcjetpilot is offline   Reply With Quote
Old January 4th, 2017, 05:14   #10
meerschm
meerschm's Avatar
This is the rear broken spring from my 2009.
http://www.myturbodiesel.com/data/ph...5214b40121.jpg
Mike
Old January 4th, 2017, 07:04   #11
calimustang
Holy rust! Im still on original springs as of 240k miles and residing in florida.
2011 JSW TDI retired and buyback, gone to heaven. almost 300k miles.
2015 Passat TDI with 22k miles on 5/6/2018, completely stock. Black exterior and black interior, 5% tints all around. Now 32k on 9/18/2018.
2014 JSW TDI bought used on 8/26/2018 with 27k miles, white with cornsilk interior. 5% tints, all stock.
calimustang is offline   Reply With Quote
Old January 4th, 2017, 10:02   #12
jaberoo
jaberoo's Avatar
I could have. If my buyback was this week, I might have. But, since it's in February, I grimaced and had it fixed.
jaberoo
Old January 4th, 2017, 11:26   #13
meerschm
meerschm's Avatar
Much safer on the road.
good decision
Mike
Old January 4th, 2017, 17:16   #14
redbarron55
Look to see if the coil was rusty at the break.
I understand that they hang the coils on a hook for painting or powder coat and where the coil hangs it misses getting paint and the rust starts there and it causes stress risers that begin the failure mode.
I think I can see a rusty spot right at the break.
Personally I think that this is a workmanship failure and should be covered if within warranty on the replacement.
If anyone replaces springs look for this and prime and paint the area f you find gaps in paint.
Old January 4th, 2017, 17:51   #15
yatzee
yatzee's Avatar
TDI(s): see sig
they always break at the bottom on the rear on those cars. We had both break on while around 2000 kms from home which was a pain, but not an issue. That was at around 110k (70k miles). The right front spring went at around 95k (55k miles), but that was probably caused by jammed top bearing jamming.
Until this car, I'd never changed coil springs under 200k
2015 Passat TDi 6 spd, 2005 C230 6 spd, 1991 405 mi16, 1986 and 1987 190e 2.3-16
yatzee is offline   Reply With Quote
Front spring broken Snowman VW MKVI-A6 Jetta Sedan (~ 2011+) 1 June 5th, 2016 05:20
Broken spring at 50k? nh mike VW MKIV-A4 TDIs (VE and PD) 12 June 24th, 2012 06:13
Broken front spring Chris B VW MKIV-A4 TDIs (VE and PD) 2 March 31st, 2010 18:42
broken rear spring dieseljunkie VW MKIII-A3/B4 TDIs 10 December 12th, 2009 09:03
Broken Spring Oreo_The_Cookie Ontario 13 December 27th, 2007 19:32
Page generated in 0.16215 seconds with 11 queries
[Output: 129.74 Kb. compressed to 107.88 Kb. by saving 21.85 Kb. (16.84%)]
