Location of Clutch Switch?
9PasCollinsat6
Beavercreek, OH
98 Jetta
I recently discovered my clutch switch to be defective (I can start the car without touching the pedal). Fantastic, because this will likely fix my cruise problem as well. However, where is the darned thing?
Lug_Nut
TDIClub Enthusiast, Pre-Forum Veteran Member
Sterling, Massachusetts. USA
idi: 1988 Bolens DGT1700H, the other oil burner: 1967 Saab Sonett II two stroke
There isn't.
The 96 Passat retains the option of being able to use the starter motor and transmission to move the vehicle out of danger.
Later models have this safety feature defeated by the use of an interlock switch.
There is a switch for the cruise control that might be slightly pushed back in it's holder to interrupt the cruise. There's another cruise switch on the brake pedal, too. Both switch's contacts have to be closed for the cruise to work. The activation switch in the turn stalk is also a known failure point.
rdkern
Humboldt Co CA
If you have a VagCom you can diagnose what isn't working.
