Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Power Enhancements
TDI Power Enhancements Archives on TDI Power Enhancement related items.
Old July 21st, 2006, 05:57   #181
Forman
Im looking at my dyno papers, and I cant figure out why whp is so low.
176bhp but only 113whp.. why?
http://www.lekerommet.net/misc/div/B...yno2_small.JPG
02 Passat Trendline PD130+
"Here's to alcohol, the cause of—and solution to—all life's problems." - Homer Simpsons
Forman is offline   Reply With Quote
Old July 24th, 2006, 03:57   #182
bencarr23
Fuel Economy: 35/42/51
Your asking the wrong Q. it should be why is my bhp so stupid hi. the whp is measured the bhp is a cal. of you whp plus the drag crap.
BHP is in almost all cases a load of crap. WHP is all that maters and all that should be used. unless you actually removed your engine then you can measure your BHP. if you didnt then stick to the WHP.
2004 Passat 2.0 PD (wifes) 2004 silver jetta PD 100 tuned by Q-loader 219 WHP 380 FT lbs D2. 339 WHP 451 FT Lbs 125 shot 1/4 mile 13.89 at 104.58 MPH 100 shot both sold
2004 F250 6.0 / 2013 Golf TDI stock 2015 challenger SRT 392
bencarr23 is offline   Reply With Quote
Old July 31st, 2006, 12:26   #183
Forman
The WHP power was very low on the run with stock engine too ... is it normal to loose 50+hp in the tranmission/drivetrain?
Old July 31st, 2006, 14:37   #184
bencarr23
no . from what i hear its between 12 to 17 %. and how low ? From the look i dont trust the #'s i would go to another dyno. or ask them what they measure.
Old July 31st, 2006, 15:01   #185
Forman
IIRC, with stock engine was 96whp
I dont have the papers on the stock engine pull, only with box and chip.
From the tuning box pull:
Corrected power - 145.5 BHP
Engine power 141.7 BHP
Wheel power 101.0 BHP
Drag Power 40.7 BHP
Max power @ 3985rpm / 162.9km/t
Torque 366.1 Nm
Max torque @ 2070rpm
Max attained RPM 4640 rpm
From the chip pull:
Corrected power - 175.9 BHP
Engine power 172.7 BHP
Wheel power 113.2 BHP
Drag Power 59.5 BHP
Max power @ 4075rpm / 197.5km/t
Torque 384.8 Nm
Max torque @ 2515rpm
Max attained RPM 4410 rpm / 213.8 km/t
Notice the difference in speed. The pull with box must be in 4. while the one with chip is in 5. .. this cant be good when trying to compare.
Also drag power is up 50% .. I dont know if this means anything, and if it does its problably because the gear difference, or?
Old August 4th, 2006, 07:40   #186
Ibiza FR
Ibiza FR's Avatar
mods are :
-larger intake with BMC panel filter
-2,5inch Milltek with downpipe and racekat
-OBD tuned
Ibiza FR is offline   Reply With Quote
Old August 10th, 2006, 13:26   #187
choramix
Fuel Economy: 6 l
Default tdi 110 afn
egr off turbo stock vnt15 afn with cat, kn box filter
here with a soft ecu chip
none
choramix is offline   Reply With Quote
Old August 16th, 2006, 19:55   #188
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Default Sootman's latest Dyno run
Title says it all. This is my latest run. I saw a reduction in torque when I added a muffler which was necessary to pass State inspection. I had just "clocked the turbo per Kerma's recommendation. Still over fueled I believe This is also a baseline for further upgrades. Looking at how linear the HP is how will "Live Mapping help?
Sootman
A friend will help you move. A good friend will help you move a body.
2011 VW Golf TDI
http://www.idparts.com/catalog/index.php
Dyno: http://forums.tdiclub.com/showthread.php?t=352348
Sootman is offline   Reply With Quote
Old August 17th, 2006, 01:49   #189
faboka
What vnt 17 you running? Is it a hybrid running that much boost?
faboka is offline   Reply With Quote
Old August 17th, 2006, 06:39   #190
Sootman
Sootman's Avatar
It's not a hybird although that would be a nice way to go. The thing will pump out over 40 psi in it's current situation but that's way to much for me to consider for a daily driver. Still getting 45-47 mpg
Sootman
2011 VW Golf TDI
Old August 17th, 2006, 08:57   #191
faboka
40 psi from a stock vnt17
Page generated in 0.17299 seconds with 10 queries
[Output: 101.38 Kb. compressed to 85.49 Kb. by saving 15.90 Kb. (15.68%)]
