Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old October 18th, 2019, 14:27   #1
Jerry.W
Default ECM change and MPG
I recently purchased a 2006 Jetta TDI and shortly thereafter the ECM failed. I replaced it with one from the junkyard with an immobilizer delete. I drove about 1k miles before the failure and it averaged about 40mpg. After I replaced the ECM it has been more efficient. My current (albeit short 120 mile) average is 50mpg. If that ECM was tuned for better economy would it retain the tune after the transplant? If not, what would you suppose is the difference? My driving is consistent and similar. The fuel is the same that was in the car. Could the monitoring system have an error large enough to give those numbers in error? I'm really curious.
Jerry.W is offline   Reply With Quote
Old October 19th, 2019, 17:54   #2
Lightflyer1
Lightflyer1's Avatar
Unless you are judging full tanks of fuel hand calculated over several tanks, you aren't comparing two similar events.
WTB 99.5 chipped ECM stage 2 or 3 i can swap good stock ECM SuperDave Private TDI Items for Sale/Wanted 3 February 26th, 2013 12:21
ECM recall combined with my free 1st oil change kgieskes VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 June 2nd, 2011 00:41
How to Change ECM for Rocketchip VelvetFoot Upgrades (non TDI Engine related) 10 November 16th, 2007 06:17
2002 Upsoluted ECM for you compatible ECM and $ Curious Chris Private TDI Items for Sale/Wanted 0 September 24th, 2003 19:55
Even Trade: My Low Smoke Upsoluted ECM for Your Stock ECM VelvetFoot Private TDI Items for Sale/Wanted 12 April 4th, 2002 23:40
Page generated in 0.08760 seconds with 11 queries
[Output: 52.24 Kb. compressed to 48.20 Kb. by saving 4.03 Kb. (7.72%)]
