Old October 17th, 2019, 09:34   #1
fase2000TDI
Fuel Economy: 52, 45 38
Default MK7 clutch towing? options? smf?
Within the next few years we plan to tow a travel trailer not exceeding 3500lbs with a MK7 GSW 6MT. I'm wondering how the factory clutch holds up towing? Would you convert to a SMF? I've read places that the SMF lead to transmission failures, but wanted to see if there was more information on this. Any pointers appreciated.
I towed a lot with my MK4 JSW with a smf and never had problems, I had hoped this would be a similar experience
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old October 21st, 2019, 16:26   #2
adjat84th
adjat84th's Avatar
I can bring you some busted synchros to Chesapeake if you'd like to see exactly what happens with a SMF and this 02Q transmission. I was one that thought had the right recipe for their survival, and it did not last more than 10k miles before losing 2nd gear.
I have a SMF in my mk4 jetta and all is fine..brass synchros will take the beating all day. Your mk7 02Q has steel unfortunately.
I'd try things out with your stock setup and if you need to replace/upgrade I highly recommend the Sachs SRE organic disc if you're keeping power under 400lb-ft.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old October 21st, 2019, 22:38   #3
turbobrick240
turbobrick240's Avatar
Yup, smf is a bad idea on these newer tdi's. I think the factory clutch will be fine with all factory parts under the hood. I'd be looking into brake system upgrades with that much in tow.
Golf Mk7 TDI 1.6 exhaust options Crumpet1996 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 3 January 18th, 2019 07:20
Sachs Quiet Clutch and pressure plate for SMF. (SMF not included) lamboworld Private TDI Items for Sale/Wanted 1 November 20th, 2017 06:45
SMF Clutch kit options OMALLEY_808 VW MKV-A5 Golf/Jettas 3 January 11th, 2015 17:33
Towing with mk7 golf tdi Asam9 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 2 January 3rd, 2015 12:20
SMF conversion clutch options - can anyone clarify? SFHGolfTDI VW MKIV-A4 TDIs (VE and PD) 4 September 24th, 2012 12:31
Page generated in 0.13194 seconds with 11 queries
[Output: 59.73 Kb. compressed to 54.16 Kb. by saving 5.58 Kb. (9.34%)]
