Old October 15th, 2019, 09:02   #1
Mass. Wine Guy
Mass. Wine Guy's Avatar
Default Stupid Wheel Well Sponge Padding
While checking to see how much debris was caught behind the plastic wheel well covers, I discovered that VW installed a large piece of foam that takes up most of that space. The foam was totally soaked.
You’d think they learned from putting similar foam in MK4 models and having to give free replacements for rusted fenders.
How do I remove this stuff to avoid rusting out?
Mass. Wine Guy is offline   Reply With Quote
Old October 15th, 2019, 09:20   #2
soot1
Can you post some pictures of what you are looking at? On 2010 models, the space behind the plastic wheel well liner was free of any foam except for the block that was sitting on top of the wheel well arch, but that one could be removed with only a gentle tug, so I'm guessing that's not the foam you have in mind, right?
soot1 is offline   Reply With Quote
Old October 16th, 2019, 06:04   #3
740GLE
2010 Mk5 had rockers rust out and replaced by VW around 2016 and 110K, foam block or not be sure to use that VW corrosion warranty!
Old October 16th, 2019, 06:38   #4
Mass. Wine Guy
There’s no sign of any rust or corrosion. But I’d like to prevent it.
Old October 16th, 2019, 09:10   #5
soot1
Prevention is a much smarter idea than dealing with a rusted-thru fender or worse, the rocker panel. If the foam is molded in place or glued, I would use whatever means necessary to remove it - brute force, spatula, solvent, brush with really stiff plastic bristles, etc, etc. Try pulling a piece of the foam out, and then try to find out if any of the common solvents, such as acetone, isopropyl alcohol, paint thinner, gasoline, eat it away. Be careful with any members of the alcohol group (methyl, ethyl, isopropyl, etc.), as they will dissolve the paint if concentrated enough. If you can identify something that eats the foam, remove as much of it as you can mechanically, and wash away whatever is left with the solvent. In any case, it is an imperative that you periodically remove the wheel well liners and clean out the accumulated crap thoroughly. After I found out about this issue, I did it annually on my old Jetta when I still owned it.
Old October 16th, 2019, 09:15   #6
Mass. Wine Guy
Definitely will follow that advice. My ‘03 Jetta wagon is rusting on one rocker panel and I’m hoping to patch it with POR 15, body repair tape and short strand fiberglass filler.
Old October 18th, 2019, 08:44   #7
740GLE
routine cleaning behind the liner will also do wonders.
Old October 28th, 2019, 12:46   #8
fase2000TDI
Fuel Economy: 52, 45 38
I'm not quite sure how you can clean water out of a sponge - just ripped them out of my 15 GSW. The foam at the 12 o clock position probably wouldn't have caused a problem, however the foam behind the liner in the wheel well is huge on the MK7. On the driver side the bottom of the foam was already absorbing moisture - it rung out like a sponge. Cleaning would help, but I'm certain if not removed this would have caused corrosion similar to the MK4 12o clock on the fender issue.
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old October 29th, 2019, 06:11   #9
740GLE
cleaning the debris, pine needles and leaves and road grime will show up after you remove that pad.
Old October 29th, 2019, 12:55   #10
Nuje
I took the wheel liner out when I was messing around with the ABS (see the "WDYDTYM7T" thread). Here's the soft almost fleecy thing on the back of the wheel liner:
As mentioned above, that doesn't feel like an issue. This, though - I'm not thrilled with this (after being parked for about six days...no rain for the last four).
I pulled it out a bit here.
And then, after squeezing a bunch of water out already, was able to squeeze even more.
Now, with all of that said, I do have to remark that the sound deadening in this car is really quite good (there's less road noise that comes through to the cabin than my wife's car, which is a MQB Audi A3 ¯\_(ツ)_/¯ ), and I have to think that those sponge blobs do a lot to help with that.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old October 29th, 2019, 14:37   #11
soot1
What 740GLE was probably hinting at is that earlier models, such as the 2010 I used to own, didn't have that huge sponge behind the plastic liner. There was just empty space there, which filled quite rapidly with all sorts of debris and organic matter. The images attached to the previous message are quite revealing - again, no such thing existed in earlier models except for the foam block at the 12 o'clock position. And I agree completely, just rip it out, or else you will be dealing with rusted fenders and rockers. Here is a link with images that show what the accumulated crap looked like on those older models without the sponge: http://forums.tdiclub.com/showthread.php?t=115274
Code 1248 problem found - stupid,stupid,stupid! Ron B VW MKIII-A3/B4 TDIs 0 January 9th, 2014 08:06
thick sponge in ccv puck causing oil leak? FL/COtdi TDI 101 4 December 10th, 2011 11:44
Stupid wheel question sisyphus Upgrades (non TDI Engine related) 3 January 27th, 2010 11:05
Stupid Wheel Bearings! hallen Atlantic Canada 12 January 13th, 2009 20:51
really really really stupid OEM wheel question blitzoid Upgrades (non TDI Engine related) 3 December 2nd, 2003 00:20
Page generated in 0.15937 seconds with 11 queries
[Output: 104.62 Kb. compressed to 88.68 Kb. by saving 15.94 Kb. (15.24%)]
