Old October 15th, 2019, 06:29   #1
jokeymaster
TDI(s): 2015 Golf
Default 2015 VW Golf Brake Fluid
hey everyone excited to be a part of this community. I am thinking about changing the brake fluid in my 2015 VW Golf. I believe the one recommended by VW is DOT 4 but I have heard that I could even use DOT 5.1 and that would work as well. Is this true? Is 5.1 going to be better than 4 in any way? I was thinking of buying the Motul brake fluid? Is there one that you have used and would recommend over the Motul?
Thank you
jokeymaster is offline   Reply With Quote
Old October 15th, 2019, 06:38   #2
kdawg89
Yeah, you can use DOT 5.1, it is better in that it has higher boiling points. Just make sure not to use DOT 5, that will destroy your brake system.
Motul is a high quality brand. If your car is a manual you use brake fluid for the clutch hydraulics as well.
15 Golf TDI SEL DSG, Kerma TDI Tunes
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old October 15th, 2019, 12:33   #3
jokeymaster
TDI(s): 2015 Golf
Old October 15th, 2019, 14:25   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
They spec DOT4 LV, not all DOT4 is LV (most isn't).
There is a difference. We use Textar or Ate or Pentosin branded stuff here.
oilhammer
www.cardocautomotive.com
Old October 15th, 2019, 20:45   #5
JM Popaleetus
JM Popaleetus's Avatar
Get this: https://www.fcpeuro.com/products/sl6...-liter-ate-sl6
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is offline   Reply With Quote
Old October 16th, 2019, 07:00   #6
thundershorts
pep boys sells 1lt pentocin dot4 for about 12 bucks.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old October 17th, 2019, 10:36   #7
Nuje
I just got the OEM stuff from my dealer for $8/500mL (CAD) - so, like $12USD/L.
Figured I'm not going to beat that price by much anywhere else...and will avoid any questions as to whether or not it meets spec (VW 501 14).
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
2015 VW Golf Sportwagen manual fluid change Luddite1811 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 4 July 17th, 2017 05:20
Dot 4 and VW brake fluid MRIBOB TDI 101 5 November 20th, 2010 09:55
VW 501 14 Brake Fluid Ol'Rattler Fuels & Lubricants 5 February 21st, 2008 23:27
Do we have to use the VW brand brake fluid? progolfer_20 VW MKIII-A3/B4 TDIs 3 February 22nd, 2006 21:59
Page generated in 0.14941 seconds with 11 queries
[Output: 78.79 Kb. compressed to 68.26 Kb. by saving 10.53 Kb. (13.36%)]
