Old October 15th, 2019, 02:10   #1
Gvillewill
TDI(s): 2011 Golf
Default DPF Back Order
Hi, I'm new to the site and new owner of a 2011 TDI Golf. Well 13,000 miles new.
About three weeks ago, my CEL popped up with two codes, 0401, 2002, DPF, EGR. After doing some research, I found out that the car was covered under the extended warranty, so off to the dealer I go. They ran their diagnostics and told me that I can't drive the car home because it would be too dangerous, but that they would order the part and I should get her back in a week.
Well, I waited about four days and then went back in to check the progress and was told that the DPF's are on back order and VW has not given them any time frame as to when the part will arrive. Then they told me that I was one of four people here in Gainesville, Fl with the same issue.
Does anybody know anything about this issue?
Gvillewill is offline   Reply With Quote
Old October 15th, 2019, 05:16   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Not heard of it, but given how these things went from about a 5% fail rate pre-fix to about a 20% fail rate post-fix I am not at all surprised.
Yet another reason why deletes will be so popular.
oilhammer
www.cardocautomotive.com
Old October 15th, 2019, 09:58   #3
Lightflyer1
Lightflyer1's Avatar
They gave you a loaner as they were supposed to do right? Let them take as long as they want and pile the miles on the loaner car instead of yours. I have read here that there is this issue going on right now. Might just be for the older cars though as the newer ones weren't getting newer parts like the older ones are.
Old October 15th, 2019, 10:34   #4
Gvillewill
TDI(s): 2011 Golf
They put me in a rental.
I'm going to do a delete, but I still have 20,000 on the warranty, so I want to wait until I'm on my own.
Old October 15th, 2019, 22:39   #5
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
VW dealers around the country have been waiting for backordered DPFs.
I replaced one for a customer on a high mileage CKRA Passat recently after his turbo failed (plus, his car was not eligible for a fix, thus he did not receive a fix, restitution nor the generous extended warranty). We waited nearly 2 months for it to show up from the dealer. And some of the VW tech pages I follow are saying the same thing, once techs finally got the DPFs they were waiting for it was right around 2 months to see the part.
And when I got mine, there was a weld partially blocking the bung for EGT #3 sensor that I had to drill out
Drilled it out in a hurry, too.. I wasn't gonna wait another 2 months for another DPF.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old October 16th, 2019, 11:28   #6
Mongler98
So typical. Makes you want to buy a VW again don't it! NOT!
Old October 16th, 2019, 12:10   #7
Matt-98AHU
Matt-98AHU's Avatar
Yeah, just more pains related to the emissions scandal and how many of these parts they needed to "fix" and put them back on the roads...
Old October 16th, 2019, 15:11   #8
Gvillewill
TDI(s): 2011 Golf
Well, I guess the good news is, It's almost one month in
Old October 16th, 2019, 21:14   #9
Mongler98
what i understand but call total BS is how they told you that you cant drive it home (for safety reasons)
are you going to be able to get into the new class action suit against VW about this MPG quota BS that they pulled? its more recent than most cases.
Old October 22nd, 2019, 11:07   #10
DivineChaos
i brought mo other jsw in because of DPF GOING BAD. they told me to drive it. would suffer with less mileage and a slight smell. i totaled the car as the dpf arrived. i put on 5k in the month i was waiting. If the motor blows its under warranty.
DivineChaos is offline   Reply With Quote
Old October 22nd, 2019, 19:53   #11
Mongler98
WHAT?
as in you got in a rek or the engine kaboomed? your saying it was due to the DPF issue? how so? too much EGT?
please elaborate!
Does anyone have a DPF back exhaust on a 2015? CTD_Chevrolet VW MKVI-A6 Jetta Sedan (~ 2011+) 0 November 2nd, 2018 18:25
DPF Problems no buy back Ruc123 Dieselgate - VW Group Emission Scandal 7 April 30th, 2018 17:58
2014 TDI - O2 Sensor on Back Order ... rickc007 TDI (Diesel) Emissions 6 October 4th, 2016 07:14
In order to get the engine back in.. G Men 08 VW MKIV-A4 TDIs (VE and PD) 8 January 19th, 2014 10:21
MAF Back order Sicnarfjr TDI Power Enhancements 3 October 10th, 2001 20:31
Page generated in 0.14195 seconds with 11 queries
[Output: 100.99 Kb. compressed to 85.46 Kb. by saving 15.53 Kb. (15.37%)]
