Old October 9th, 2019, 09:40   #1
T4RBoarder
Fuel Economy: See Fuelly!
Default Tallest tire for 16" wheel on a GSW
Hey guys,
I promise I have searched and I really apologize if this has been covered already for a MK7 platform vehicle.
I drive on some pretty poor and un-maintained roads in the winter and am trying to figure out the tallest tire I can stuff on a 16" wheel (VW steelies) under my stock GSW for a snow setup.
I've seen threads for the MK6s saying that a 205/60/16 is the tallest tire that will fit on a stock height vehicle without rubbing. Does anyone know/have experience with fitting a 205/65/16 on our MK7 cars/a GSW or is a 60 series tire the tallest I can do?
Appreciate the help.
-Aaron
T4RBoarder is offline   Reply With Quote
Old October 10th, 2019, 06:09   #2
740GLE
been posted about 15 times, 215-65-16 is good to go.
Old October 10th, 2019, 06:54   #3
T4RBoarder
Right after I posted I found a recent thread about the regular GSW. I SWEAR I hadn't found anything prior except for the Alltrack. I appreciate the help though.
-Aaron
Old October 28th, 2019, 12:49   #4
fase2000TDI
Fuel Economy: 52, 45 38
Can confirm that 215-65-16 fits and looks awesome. One downside I did notice is that you definitely can feel you're on taller tires if you aggressively change speeds at highway speed. The trade is worth it for the ground clearance - it's still very stable at high speeds.
TDI service available - timing belts, clutch jobs, cv joint rebuilds, engine rebuilds, maintenance, low power diagnosis, suspension. DSG service $180 Have CAN VCDS for CR TDI's PM here, call or email JeremyTDI@yahoo.com (401)-919-0466 Quotes available, very fair rates
fase2000TDI is offline   Reply With Quote
Old October 28th, 2019, 13:20   #5
dubStrom
dubStrom's Avatar
I put 215 tread width tire on mine.
215/60R-17 CONTINENTAL TRUECONTACT SL
THese are about 28" tall and fit tight in the wheel wells. But they do not rub the fenders. I do get contact when I have the steering pined left or right, but that is a creeping speed and I usually back off from pinned a bit before moving or just don't pin it left or right.
I've have been very happy with these. A softer ride than OEM (was ContiPro Contact 225/45R-17 which were much shorter). THese 215/60R tires have much more meat on the sidewall, and they provide a more comfortable ride without much compromise on high speed corner drift. I don't do much of that anyway. I have a 9% speedo error which I will address in the tire size (snow tire accomodation?) in VCDS when I have time. It is easy to keep track of a near 10% error, and my wife doesn't know I am speeding
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
dubStrom is offline   Reply With Quote
Old October 29th, 2019, 06:14   #6
740GLE
thats massive! i thought 225-55-17 filled out the wheel wells and rode nice, jeeze!
Old October 29th, 2019, 09:28   #7
r90sKirk
r90sKirk's Avatar
And my snowies that I run on my GSW are 225/60/16 - they do not rub either - very sure-footed!
Honest TDI Enthusiast Performing Competent TDI Work
Currently Owning: 2006 Jetta TDI Laser Blue 269k, 2015 GSW (6MT) Pure White 78k, 1977 BMW R100RS 166k Silver Ice,
Gone, but not forgotten: 2013 Passat TDI SE 151k Opera Red, 2002 Jetta TDI Cool White 248k, 2000 Golf TDI 461k Bright Green, 1997 Jetta TDI Green 290k, 1996 Passat B4V Indian Red Pearl 337k
r90sKirk is offline   Reply With Quote
Old November 2nd, 2019, 08:15   #8
jerrymander
jerrymander's Avatar
235 55 17 is where rubbing starts. The sidewalls on mine are chewed up in the front. Doesn't rub in the rear at all, though. I imagine if you put Eibach springs (or really anything other than VW) the rubbing would go away.
jerrymander is offline   Reply With Quote
Old November 4th, 2019, 11:16   #9
740GLE
So just the sidewall on the strut? maybe a 10mm spacer will help?
16" winter wheel and tire set geektoad Private TDI Items for Sale/Wanted 0 December 6th, 2011 20:26
2010 Jetta TDI 16" Tire and Wheel Upgrade To 17" Michelin Primacy MXM4 darrelld Upgrades (non TDI Engine related) 2 December 26th, 2010 12:49
Recommended pressure for 16" wheel/tire halfast3 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 December 24th, 2010 13:40
16" Snow tire and wheel package czar Private TDI Items for Sale/Wanted 4 December 7th, 2009 14:08
Tire Wheel Size Test (18" to 16") MCathcart TDI Fuel Economy 26 April 9th, 2008 10:56
Page generated in 0.18760 seconds with 11 queries
[Output: 94.30 Kb. compressed to 80.71 Kb. by saving 13.59 Kb. (14.42%)]
