Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old October 8th, 2019, 21:50   #1
Andyinchville1
Default /// in tank electric fuel pump for better mileage? ///
Hi all,
After getting my car back to running condition I noticed that my clear fuel line now has a stream of small bubbles in it...
While some people say that small bubbles are normal it kind of makes me a little paranoid and in my readings to help you eliminate the air bubbles I read that somebody had put an electric fuel pump and that cured their air bubble situation.
That got me to thinking about other products that help remove air from diesel and some people even allege that it helps with performance...
Well I know some things like electric fans vs mechanical fans helps to increase fuel mileage would simply adding an electric fuel pump was it was none prior help to increase fuel economy by reducing the need for the pump to suck fuel as well as possibly eliminating all the air bubbles in the clear fuel line?
Has anybody here installed an electric fuel pump and notice any change in fuel mileage or performance?
Thanks in advance for any and all help
Andrew
2003 Jetta tdi wagon , 5 sp, 316k miles, 11 mm pump, DLC 520, Malone stage 1, P205 70 R 15 Ecopias on Avus rims, hammer mod
Andyinchville1 is offline   Reply With Quote
Electric Fuel pump B2TomTom VW MKV-A5 Golf/Jettas 2 May 3rd, 2014 16:25
Electric fuel lift pump Jeep/1947 TDI 101 5 November 7th, 2009 18:51
F.S. Electric Fuel Pump truszip Private TDI Items for Sale/Wanted 3 January 29th, 2009 17:38
Electric pump for Bio in a Blitz 5 gallon tank? Charm Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 15 August 14th, 2006 08:55
Does a B4 have a lift pump or electric tank pump? 2TDIguy VW MKIII-A3/B4 TDIs 1 December 6th, 2005 07:41
Page generated in 0.12601 seconds with 11 queries
[Output: 47.62 Kb. compressed to 44.87 Kb. by saving 2.75 Kb. (5.77%)]
