Old October 8th, 2019, 13:25   #16
RIP TDI
Originally Posted by oilhammer View Post
but none of the A7 TDIs got the electric heater, as I assume they felt it was not necessary or (more likely) they were trying to save a few bucks.
Apparently all A7 TDIs have the 7E6 "Electric Auxiliary Air Heater", but NOT the 9M0 "Auxiliary Heater".
If you're looking for the 7E6 option code on your build STICKER (located underneath the hatch threshold trim panel), you won't find it, since the sticker doesn't list all equipment on your car. The build SHEET does list all equipment codes & descriptions.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old October 8th, 2019, 16:40   #17
JM Popaleetus
JM Popaleetus's Avatar
I have my factory manifest and I definitely do not have 7E6.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is offline   Reply With Quote
Old October 8th, 2019, 17:10   #18
The Tortoise
I have the 7E6.
Canadian Trendline.
The Tortoise is offline   Reply With Quote
Old October 8th, 2019, 17:16   #19
RIP TDI
Interesting...
My GSW was purchased new in Baltimore and does have 7E6 (near the very bottom of the list). Assuming yours was originally sold in Conn., I can't believe there's that small a regional difference. Yours is a hatchback, right? Could it be HB vs. GSW? A logical explanation eludes me.
- Chris
'99 BMW M3 Cabrio
Old October 8th, 2019, 17:54   #20
The Tortoise
I have the GSW
Old October 8th, 2019, 18:59   #21
JM Popaleetus
Interesting...
Originally Florida. Hence why I thought it might be a 'Hot Country-only' model.
But apparently that doesn't exist?
Most likely it just comes down to typical VW assembly line randomness.
Old October 8th, 2019, 19:59   #22
RIP TDI
Do you have "7E0: W/o heat accumulator/auxiliary heating" on your sheet?
I'm wondering if the heating hardware is present on all cars in a national market but activated in some and not others, with the build sheet reflecting whether it was activated or not at the factory. That begs the question: is there an activation adaption or long code change in VCDS? Do I remember a post about this a few years ago or is this just wishful thinking?
- Chris
'99 BMW M3 Cabrio
Old October 8th, 2019, 22:47   #23
JM Popaleetus
Here is everything, in order, that is (or could be) relevant to the discussion on my manifest:
8GU - 140A Alternator
0Y4 - Climatic zones: Cold and tropical climatic zones (US).
8Z6 - Engine cooling system: Hot country.
7E0 - Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating.
9M0 - Auxiliary heater: Without auxiliary/parking heater.
Old October 9th, 2019, 04:24   #24
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
OK so evidently this electric heater is NOT part of the cold country packaging on the A7s, or at least, not on yours.
The "parking" heater is the fuel fired one, Webasto and Ebersbacher are the two big suppliers of these. No US spec Volkswagen after the Vanagon has had one of these available.
ETKA shows two PR codes for the electric heater, 7E6 and 7E0, with 7E6 showing the part number and 7E0 simply stating "not for this model".
It kinds of sounds like the heated seats in older cars. Some had it, as part of a "Cold Weather Package", but it was not specifically part of the Cold weather country buildout, which by default all US spec cars are.
Question is, did anyone at a dealer actually have the ability to line item order that or not. Ordering for the US market has always been spotty.
oilhammer
www.cardocautomotive.com
Old October 9th, 2019, 04:37   #25
JM Popaleetus
I've toyed with the idea of buying the electric heater core off eBay for ~$40 or so and installing it. But I've found the EA288 heats up much faster than the EA189 as intended to the point I can't be bothered.
But looking at this thread and the other, it seems that all GSW's have it while the hatchbacks do not. So I'll submit that as my answer.
Old October 9th, 2019, 04:46   #26
RIP TDI
Here's mine:
7E6 - Heat accumulator system/auxiliary heater: Electric auxiliary air heater
- Chris
'99 BMW M3 Cabrio
Old October 10th, 2019, 06:13   #27
740GLE
what part of this discussion is about AC issues?
Old October 10th, 2019, 22:28   #28
Ooga
So again, without overthinking this, scan tool ---> verify coding, check pressure (scan tool pressure, I do not care what a gauge says)
How come you don't care what a gauge set would read? Im not familiar with vehicle specific stuff but in my world we love verifying with gauges. Thanks for whatever education I'm about to receive.
Ooga is offline   Reply With Quote
Old October 11th, 2019, 04:19   #29
oilhammer
oilhammer's Avatar
Because that is the output, we want to check the input first. In the input is bad, then you already know the output will be bad.
Plus, and I have to educate the masses at our shop on this repeatedly, every single time you hook gauges up to an automotive A/C system, you've discharged it some. Every. Single. Time. The level of refrigerant just is not that much. The volume to fill the machines hoses and valving inside is not an insignificant percentage of the total volume of refrigerant on so many of these modern cars. And these cars are VERY picky about having the correct charge.
A Civic will be working just fine... if you put gauges on it, just the act of "checking" the pressures... it will no longer work as it was prior. They are THAT sensitive.
The cars in question have a pressure sensor (high side). That value can be monitored via the Climate's data blocks. No need to mess with any gauges for that. If you have exhausted all other control side means, and you still feel like something is not right, but the system IS working, then perhaps as a last ditch diagnostic tool. Otherwise, the only time the service ports get touched is if the system is going to be evacuated and recharged (for whatever reason... we often do this to service something altogether unrelated to the A/C system).
oilhammer
Old October 11th, 2019, 16:33   #30
Ooga
Makes complete sense. We have cool little pressure readers we like to use that don't have lines for the same reason on small systems. thanks for the info.
WTB: 2015 Golf TDI Comfortline 6M - Highline (Vancouver, BC) garms TDI Cars for Sale/Wanted 2 December 19th, 2016 11:38
air conditioning not cold Truckdriver09 VW MKIII-A3/B4 TDIs 36 April 15th, 2016 05:58
2015 Golf TDI SE 6M 8k ottomatic TDI Cars for Sale/Wanted 17 March 20th, 2015 11:03
GOLF MK4 TDI - Cold air blowing from heater @ standstill GOLFA VW MKIV-A4 TDIs (VE and PD) 4 December 2nd, 2012 05:24
Air conditioning trouble shooting? Vents blowing warm air. Keven VW MKIV-A4 TDIs (VE and PD) 0 May 21st, 2012 08:12
Page generated in 0.17461 seconds with 11 queries
[Output: 134.77 Kb. compressed to 112.62 Kb. by saving 22.15 Kb. (16.44%)]
