Old October 5th, 2019, 13:55   #1
JSWThinker
Default 2015 Golf TDI SportWagen S, 6M - Air Conditioning Not Blowing Cold Enough...
Low pressure side shows within spec.
I've been reading a few different things about common issues where the AC doesn't blow cold enough on these cars. I did not do a delta on input/output... but I can assure you, not even close.
Is there a known issue that may be more common than another?
Any other thoughts?
Thanks,
Pete
2014 VW Jetta SportWagen TDI / Candy White - Cornsilk / 6M / Base
JSWThinker is offline   Reply With Quote
Old October 5th, 2019, 19:11   #2
jerrymander
jerrymander's Avatar
Air bubble in freon?
jerrymander is offline   Reply With Quote
Old October 6th, 2019, 02:03   #3
Ooga
Air bubble in the freon is not a thing..at least it the household/commercial area....that i am aware of.
Im really curious about the air in/out temps you are getting. Also, did this problem just start or has it always been this way? I can't comment on common issues with this vehicles A/C but I do work in the industry but not on the vehicle side. I'm always glad to help if i can.
Ooga is offline   Reply With Quote
Old October 6th, 2019, 18:06   #4
JM Popaleetus
JM Popaleetus's Avatar
Make sure your car is set to Hot Country. And otherwise, I’d definitely bring it to an AC shop.
My Golf’s AC is definitely strong enough to get uncomfortably cold even after sitting on a muggy 100į+ day.
Nothing compares to my Volvo which I’m pretty sure could freeze ice.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is offline   Reply With Quote
Old October 7th, 2019, 06:32   #5
740GLE
could be low on R134a, could be RCV valve and could be hot country no being set, but my guess is the first two.
Old October 7th, 2019, 07:50   #6
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
We replaced the compressor in our 10 JSW this summer. Glad we got to it before summer refused to leave the Carolinas.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old October 7th, 2019, 10:22   #7
KITEWAGON
KITEWAGON's Avatar
Isn't there some kind of TSB for the RCV valve? If anyone has a reference please post it because I realized that mine is doing the exact same thing. It blows cool but not cold. It just barely, kind of almost keeps up on a typical 85 F summer day in New England. It sounds very similar to what the OP has for an issue. Although I just realized his is a 2015 and mine is a 2014 so its a different platform.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old October 7th, 2019, 10:28   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yes, there is a TSB. The distillation of it is: replace the RCV. In some instances, they get a new compressor, but that is if the poor cooling is accompanied by a noise.
But I agree on the A7 Golfs you need to make sure the Hot Country is coded in the Climate module, evidently some were not coded correctly.
oilhammer
www.cardocautomotive.com
Old October 7th, 2019, 11:56   #9
JSWThinker
Thanks for all the replies!
The AC was never "very good" -- but it has gotten much worse.
I can measure delta, but I assure you, nothing like it should be.
I'm interested in the "Hot Country" thing. The car was a 2015 that was bough in 2017 after DieselGate (I sold back my 2014 TDI)... the car came from Colorado (I had it trucked)... and I always wondered if that had anything to do with it. I live in South Florida.
Do I need an ODB-Eleven to to deal with that? Is that really a feasible issue?
@ 85f ambient temp the low side pressure was at the high-side of the range (range is 45-55, mine was 55).
The compressor sounds to be turning on and off... but again, if you guide me, I can triple check and report back.
Old October 7th, 2019, 12:09   #10
oilhammer
oilhammer's Avatar
The compressor has no clutch, so it is always spinning. The RCV controls (via duty cycle) the amount of displacement the compressor has, which varies from 0% to 100%.
All US-spec vehicles will be equipped for both hot and cold climates, if there is a setting or equipment that dictates such, because we have both. Volkswagen does not make "regional" spec cars. Canada may only get cold country, and Mexico may only get hot country, but we get both (if that makes any sense).
You will need an appropriate VAG-capable scan tool to verify the coding of the Climate module. You will also need same for verification of compressor command, duty, and pressure. However, given the now decade+ issue of dealing with RCVs in all kinds of compressors, I would say more than likely that is the source of the issue.
I feel like the process by which the components of the A/C system are manufactured and cleaned before assembly is much to blame, as small particles get lodged in the RCV's tiny orifices and screen, and make it stick not allowing full displacement stroke of the compressor, and thus slow to cool and poor cooling in general. Because most of the time, like 95% of the time, once the car's original RCV (and related manufacturing leftovers trapped within) is replaced, that car's system works fine and will continue to do so.
So again, without overthinking this, scan tool ---> verify coding, check pressure (scan tool pressure, I do not care what a gauge says) and command (if you want, since you really won't know exactly what you are looking at, you can always do a before and after), then replace the RCV.
oilhammer
Old October 7th, 2019, 12:17   #11
JSWThinker
Sounds like a great plan. I'm assuming an old fashioned ODB2 tool isn't going to do squat compared to the ODB Eleven, correct?
Old October 8th, 2019, 08:28   #12
740GLE
odb eleven and vcds would be the best to invest in.
Old October 8th, 2019, 12:56   #13
JM Popaleetus
Good to know that the compressor is always spinning. Now I don’t have to feel guilty about always leaving it on even when it’s colder outside.
Are you sure about this for the MK7?
Mine was originally sold in Florida, and while Hot Country was enabled by default, mine does not have the electric auxiliary heater.
Old October 8th, 2019, 13:01   #14
oilhammer
oilhammer's Avatar
Originally Posted by JM Popaleetus View Post
Good to know that the compressor is always spinning. Now I donít have to feel guilty about always leaving it on even when itís colder outside.
And ALH cars didn't get the Webasto fuel fired heater like the extreme Northern countries had access to. I guess VAG's definition of hot and cold vary, but none of the A7 TDIs got the electric heater, as I assume they felt it was not necessary or (more likely) they were trying to save a few bucks.
But as I said, US spec cars are US spec cars. Period. There is no variation. The cars sold new in Florida are the exact same as the cars sold new in Wisconsin.
oilhammer
Old October 8th, 2019, 13:07   #15
JM Popaleetus
...none of the A7 TDIs got the electric heater, as I assume they felt it was not necessary or (more likely) they were trying to save a few bucks.
http://forums.tdiclub.com/showthread.php?t=495374
Couple people claimed to have it installed, which is why I asked you, that’s all.
WTB: 2015 Golf TDI Comfortline 6M - Highline (Vancouver, BC) garms TDI Cars for Sale/Wanted 2 December 19th, 2016 11:38
air conditioning not cold Truckdriver09 VW MKIII-A3/B4 TDIs 36 April 15th, 2016 05:58
2015 Golf TDI SE 6M 8k ottomatic TDI Cars for Sale/Wanted 17 March 20th, 2015 11:03
GOLF MK4 TDI - Cold air blowing from heater @ standstill GOLFA VW MKIV-A4 TDIs (VE and PD) 4 December 2nd, 2012 05:24
Air conditioning trouble shooting? Vents blowing warm air. Keven VW MKIV-A4 TDIs (VE and PD) 0 May 21st, 2012 08:12
Page generated in 0.16129 seconds with 11 queries
[Output: 133.76 Kb. compressed to 111.92 Kb. by saving 21.84 Kb. (16.33%)]
