Old September 26th, 2019, 09:55   #16
740GLE
looks like gti carriers, kinda surprised they didn't offer to paint the caliper to match, but then again red is tough to match.
740GLE is online now   Reply With Quote
Old October 2nd, 2019, 17:02   #17
thundershorts
Will the 312 rotors and gti calipers fit using stock golf s 16" wheels? Or rather will the wheel clear?
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old October 3rd, 2019, 10:05   #18
740GLE
should, i run biolines (16x6.5 et50) from my 2010 jetta on our Alltrack wit 312's, just be sure of wheel weights, you want them on the inside of the rim and low profile as well, otherwise the rotor will clean them off for you.
Old October 3rd, 2019, 13:42   #19
thundershorts
Thanks 740, I just bought a couple 3k mile gti calipers. Textar rotors supposedly are top tier quality so it might make sense to use them. Should add a little bling with the red calipers.
Old October 4th, 2019, 07:13   #20
740GLE
report back, I really enjoy the pedal feel of our Alltrack 312, for a DD I couldn't really ask for more.
Old October 4th, 2019, 07:37   #21
thundershorts
I will report back 740, but it might not be right away. They may go on my friends newly acquired 17k sportwagen with 16" or on mine with austin 18".
Old October 6th, 2019, 06:25   #22
thundershorts
https://www.1aauto.com/vw-audi-front...1348493&y=2015
88/pair drilled, slotted, coated
Old October 7th, 2019, 11:01   #23
thundershorts
Same seller 1aauto.com sells pair of rear 252mm rear drilled/slotted coated rotors for 26 bucks.
Old October 15th, 2019, 07:22   #24
thundershorts
Installed the 312's on my friends gsw under the stock 16" wheels. there is about 11mm clearance caliper to wheel. The pads aren't seated yet so far they feel good compared to the crappy pitted ones that came off. The red calipers give it added bling as well as the drilled, slotted look.
Old October 18th, 2019, 08:24   #25
sprstu
Fuel Economy: average:42 best:48
Here is my upgrade to stock GTI non-performance front.
The stock Caliper is the same only item needed is the caliper carrier. Many people who upgrade their GTI to the PerformancePack or Golf R sell off the old stuff. I bought these used for $75shipped on VwVortex. I opted to not buy the red caliper, I can paint my own stock units later.
I just need to remember to shop for 2015 GTI brake parts when they need replacing again in the future. I did not do any stopping tests and really day to day I don’t think it makes any difference except for the peace of mind and vanity of the larger brakes. I’m sure they do stop better and handle more load but while sitting in traffic...
81 Caddy 1.6TD
2015 Platimun GSW 6spd, post fix Kerma Tune
sprstu is offline   Reply With Quote
Old October 18th, 2019, 08:36   #26
740GLE
I'm sure you could lock up and activate ABS with 288 front rotors, what the 312 will get you is better heat dissipation and improved "performance" under repetitive stopping.
Also Alltracks and passats have 312 non painted carriers,
Either way cheap upgrade if you already needed rotors. Also I hope you prepped the mating surface of the hub and tossed on some antisize, you're future self will thank you.
2015 TDI Brake Upgrade steve1479 VW MKVI-A6 Jetta Sedan (~ 2011+) 14 April 5th, 2016 11:51
Golf brake upgrade... bodid VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 July 16th, 2015 20:51
Golf MKVI brake upgrade Noismyname Upgrades (non TDI Engine related) 4 November 9th, 2014 17:55
What brake upgrade for golf mk5 ??? 2STROKECORKY Upgrades (non TDI Engine related) 12 February 8th, 2013 11:33
Golf Brake Upgrade andyabt Upgrades (non TDI Engine related) 1 September 28th, 2007 18:42
Page generated in 0.18499 seconds with 11 queries
[Output: 101.94 Kb. compressed to 85.96 Kb. by saving 15.98 Kb. (15.67%)]
