Old September 9th, 2019, 21:01   #1
tdiman
tdiman's Avatar
Default Extended crank time when first starting.
Wondering how many people driving a Jetta /golf EA288 2015 have notice a few extra cranks in the morning when starting?
tdiman is offline   Reply With Quote
Old September 10th, 2019, 02:52   #2
Jaybean
Mine is after its warm and been started for the day.
Sent from my SM-N960U using Tapatalk
Jaybean is offline   Reply With Quote
Old October 12th, 2019, 15:53   #3
tdiman
tdiman's Avatar
I'm thinking now it may need a battery currant battery is only 42 ah vw requires a 72 amp hour battery .
Old October 12th, 2019, 20:00   #4
scooperhsd
Yeah - make sure the place you goto installs an H6 (Group 48) battery and not an H5 (because it has "enough CCA").
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old October 13th, 2019, 10:15   #5
k0wtz
TDI(s): 1998
My 1998 beetle doing the same thing I am thinking my fuel is draining off. I don't see how a different battery will help. My car has 200k on it I may be also lacking compression?
just my thoughts
k0wtz is offline   Reply With Quote
Old October 13th, 2019, 10:39   #6
scooperhsd
My 2000 NB has 371,000 miles, and one glowplug needs replaced (rounded off - for about 6 years now) and it has no trouble starting clear down to below 0 F if I have a good battery in it.
Old October 13th, 2019, 10:42   #7
tdiman
tdiman's Avatar
I'm pretty sure that it's the battery I put a charger on it and it cranks right over I have a aftermarket battery Autocraft gold 48H6
Extended crank to start help! irocz28 TDI 101 3 July 25th, 2013 06:20
Extended crank CTD01 VW MKIV-A4 TDIs (VE and PD) 4 April 30th, 2012 09:00
extended crank time when hot rmorton102 VW MKIV-A4 TDIs (VE and PD) 5 October 1st, 2008 10:23
Extended Crank? HOOKER76 TDI 101 9 October 6th, 2006 10:01
Starter causing extended crank time when warm? SCCAFV17 VW MKIV-A4 TDIs (VE and PD) 3 May 6th, 2004 06:15
Page generated in 0.11617 seconds with 11 queries
[Output: 77.49 Kb. compressed to 67.11 Kb. by saving 10.38 Kb. (13.40%)]
