Old May 7th, 2019, 15:23   #1
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
Default Timing belt change, but advanced on vcds graph
Hello all,
I have replaced my timing belt.
I have a manual and got the notch on flywheel.
I locked the cam and fuel injection pump pulley.
I matched the first crankshaft sprocket dot with the notch on the block and the other two dots followed to the right.
I reassembled the motor.
It started right up, but was rough and smoked pretty bad.
The car sat for 4 months, I thought that is why it was smoking since t started right up with no adjustment.
The VCDS shows the timing to be too far advanced to be plotted.
I retarted it all the way mechanically. It is still too far advanced to be graphed. It smokes less, but I know what turbo feels like and I don't have it. Yes, all my vacuum lines are connected.
I seen a video on YouTube that says you can advance the timing to 33268 instead of 32768. Can I retard the timing to 32268?
Please let me know your thoughts. I am really new to this.
https://imgur.com/85D4ryO
Your Animation Hero!
Dreznon is offline   Reply With Quote
Old May 7th, 2019, 16:00   #2
Tdijarhead
So you adjusted it at the cam sprocket by loosening the 3 bolts? Where are those 3 bolts in their respective slots? More or less centered or all the way against one side or the other?
Tdijarhead is online now   Reply With Quote
Old May 7th, 2019, 16:51   #3
KLXD
Sometimes if the timing is off enough VCDS reports the opposite condition. I guess it's picking up the next cylinder. So try retarding it.
This is strange because the ALH usually requires little adjustment.
What's this mean: "I matched the first crankshaft sprocket dot with the notch on the block and the other two dots followed to the right."?
When you set the tensioner were the three pump sprocket bolts loose and was the cam sprocket loose on the shaft so it could rotate?
After setting the tension bur before torquing the cam and pump sprocket bolts did you verify that the crank was still at TDC?
If your static timing is off you shouldn't be messing with VCDS to bring it in.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old May 7th, 2019, 22:18   #4
AndyBees
AndyBees's Avatar
I think the OP has botched the TB job.
I suggest that he start over ........
1. Set the engine on TDC by the timing mark on the Flywheel (transmission end of engine).
2. Loosen the Cam Bolt and break the Sprocket Cog loose. <<<< EDIT: I didn't say remove, just loosen the bolt two or three turns.
3. Insert the Cam locking tool
4. Loosen the three bolts holding the IP Sprocket Cog
5. Insert the pin in the IP.
You may need to nudge the crankshaft forward or backward a bit......... typical.
Try to set the physical timing so that the three bolts in the IP Sprocket are centered in the slots............. it will be damn close in time if you do this!
Hope this helps!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old May 7th, 2019, 23:44   #5
Vince Waldon
Vince Waldon's Avatar
Step 2 *very* important... and if you skip this step strange timing things happen.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old May 8th, 2019, 05:34   #6
jettawreck
jettawreck's Avatar
Suggest a read thru a couple times to get the proper steps in mind and then follow it as the job proceeds...
http://pics3.tdiclub.com/pdf/a4timingbelt.pdf
2004 Cadillac SLS (wife's)
Old May 8th, 2019, 12:49   #7
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by Dreznon View Post
..........................................I seen a video on YouTube that says you can advance the timing to 33268 instead of 32768. Can I retard the timing to 32268?.....................
You can do this (it's actually recommended in one of our old FAQs) but first you want the timing right in the middle. Sounds like you just need to go back to the mechanical time step with the bolts loose as you re-tension. Then fine tune with the IP pulley bolts using VCDS or equal.
BobnOH is online now   Reply With Quote
Old May 8th, 2019, 12:54   #8
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
They are all the way retarded, as far as they can go.
VCDS shows timing 255.
Old May 8th, 2019, 12:57   #9
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
I never removed the cam sprocket.
can I fix this with the motor assembled?
Old May 8th, 2019, 12:58   #10
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
On it!
Old May 8th, 2019, 13:01   #11
flee
flee's Avatar
Fuel Economy: 40-ish
Removed or loosened?
'Breaking it loose' is necessary but not actually removing it though it frees up some room.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old May 8th, 2019, 13:04   #12
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
I was thinking if I am able to loosen the belt somehow with the motor assembled then I could retard the IP pulley 21 teeth (8 degrees) per tooth. moving within the holes does not retard it enough to budge but a few degrees and since I am sitting at 255 on VCDS then that is 21 teeth. In theory.
If you guys have a suggestion of loosening the belt with the motor assembled then please let me know and I will do it one tooth at a time on the IP until I get it to 65.
I am pretty sure that's what I need to do, no?
Old May 8th, 2019, 13:05   #13
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
I did not.
Old May 8th, 2019, 13:17   #14
flee
flee's Avatar
I did not.
Ah, well go through the correct procedure and then you'll see if the IP sprocket is off
by the position of the screws in the slots. Get the holes as close to center of the slots as
as you can with the locking pin in place. It may be a tooth or so off, so correct it now.
Old May 8th, 2019, 13:18   #15
Dreznon
TDI(s): ALH
Fuel Economy: 40mpg
correction, yes the lobes were up!
Injection pump timing too advanced (VCDS says) h1h0silver VW MKIV-A4 TDIs (VE and PD) 8 July 22nd, 2018 21:03
VCDS timing graph? dweisel VW MKIV-A4 TDIs (VE and PD) 10 January 25th, 2018 19:17
Can't get timing graph to show up, VCDS! turbovan+tdi OBD Scanners 0 February 29th, 2016 13:09
unable to read timing graph in VCDS xtremetractorteam OBD Scanners 12 March 27th, 2009 16:58
Timing too advanced to plot graph blued TDI 101 5 July 5th, 2007 04:17
Page generated in 0.18971 seconds with 11 queries
[Output: 132.47 Kb. compressed to 110.16 Kb. by saving 22.31 Kb. (16.84%)]
