Old April 16th, 2019, 08:56   #1
petee_c
Fuel Economy: 5.6ish L /100km golf.... just under 10L/100km q7
Default trailer hitch install -2015 Golf Hatchback?
Who's installed a trailer hitch on a 2015 Golf TDI?
Doing some preliminary research, it looks like you can get hitches for non -R models, and R models...
I ASSume that the TDI would just use the non-R model, they don't differentiate between gas and diesel.
Any drilling required?
How was the wiring hookup?
I have a lot of tools, so I am thinking about doing it myself...
Amazon has this Curt 11412 hitch, but it doesn't say compatible with TDI on Amazon's checker...
https://www.amazon.ca/CURT-11412-Cla...olkswagen+Golf
petee_c is offline   Reply With Quote
Old April 16th, 2019, 10:04   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Go back to the Amazon page and click on the "Trim" button...
-George Bernard Shaw
Old April 16th, 2019, 10:38   #3
laminated
Amazon was the best price by far, 3 Things I had done,1 put a plate at the back of the receiver so water doesnt get in. Get a 1/2" grommet and cut it in two, then glue each half over the pin hole to keep moisture out of that area.and underneath, drill a 3/8" hole near where the end of the drawbar will reach into the receiver. You then weld a 3/8" nut over the hole. Then get a stainless bolt for it. (wont rust). when you install the drawbar, you can tighten the bolt up into the base of the drawbar. it stops that clunking noise.
laminated is offline   Reply With Quote
Old April 16th, 2019, 10:55   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Originally Posted by laminated View Post
Amazon was the best price by far...
Maybe up there in Canada, but idparts has the Same Hitch for a lot less down here.
Old April 16th, 2019, 11:07   #5
petee_c
$149USD = $198cdn pesos
exchange rate is $1US=$1.33cdn...
plus free 2 day shipping....
Old April 16th, 2019, 12:27   #6
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Whoa! I didn't realize that the exchange rate was that bad.
Old April 17th, 2019, 09:31   #8
petee_c
thanks all,
I've decided to get the Curt Hitch from Amazon... for me in Canada, can't beat the price.. looks to be a simple install...
next onto research for the wiring ... what did you guys use?
Likely use will be for a 4x6 utility trailer to take stuff to the dump or bring project supplies home from the lumberyard.
Old April 17th, 2019, 14:04   #9
pdh
Fuel Economy: 42/49 VW, 38/42 BMW
I inquired at a hitch installing garage & they refused to install one because of the trailer weight limit on my 2015 Golf TGI S (liability concerns).
I own a pontoon boat and need a hitch to move the boat 3 blocks. The hitch company told me that the potential tongue weight could lift the front wheels off the ground as well as affect braking. I realize others are towing, but I decided to be prudent and just forget the hitch idea altogether.
pdh is offline   Reply With Quote
Old April 17th, 2019, 14:57   #10
Nuje
Towready #118646, or something to that effect; simplest trailer wiring you'll ever do. Literally plug and play for the Golf - a bit of futzing about if you're in a Sportwagen.
Details here: http://forums.tdiclub.com/showthread.php?t=446936
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old April 17th, 2019, 15:37   #11
Lightflyer1
Lightflyer1's Avatar
Is the tongue weight more than 200 lbs? That is what the hitch and car will handle. Especially at those short distances. If it is more is there anything you can do to move the boat back some to reduce the tongue weight?
Old April 18th, 2019, 06:26   #12
740GLE
OMG, how could they forget to mention you're car will also over heat and launch the 1600F turbo into your face soon as you install any hitch, let alone the fact the DSG will immediately spin both clutches and grind all 6 gears to a fine metallic paste.
People install hitch for bike racks that probably place way more than 200lb of stress to the hitch mounting points.
740GLE is online now   Reply With Quote
Old April 19th, 2019, 14:26   #13
JM Popaleetus
JM Popaleetus's Avatar
Originally Posted by 740GLE View Post
OMG, how could they forget to mention you're car will also over heat and launch the 1600F turbo into your face soon as you install any hitch, let alone the fact the DSG will immediately spin both clutches and grind all 6 gears to a fine metallic paste...
He posted why, no fluff needed:
...liability concerns...
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is online now   Reply With Quote
Old April 23rd, 2019, 06:16   #14
740GLE
liability of a bike rack?
Didn't know Thule, 1up and Kuat were murderous evil corporations hell bent on harming people and turning cars into death traps.
Old April 23rd, 2019, 06:52   #15
JM Popaleetus
Itís clear you donít understand how liability works.
Itís completely understandable why an installer wouldnít want to install a hitch for boat towing on a small car thatís not rated for it in the USA. Even though the drivetrain is more than capable.
But by all means, continue to be an ass.
Trailer hitch install mcad64 Ontario 4 March 10th, 2012 13:21
2007 Golf hatchback: tow bar (hitch) install dieseloz TDI 101 9 July 15th, 2007 23:04
Trailer hitch for Golf - where to buy & install sportsguy Atlantic Canada 18 June 7th, 2006 18:33
Trailer Hitch Install Issues mikeyworks Upgrades (non TDI Engine related) 4 September 23rd, 2005 08:45
Trailer Hitch Install milehighassassin Upgrades (non TDI Engine related) 6 August 3rd, 2005 10:48
Page generated in 0.17085 seconds with 11 queries
[Output: 131.82 Kb. compressed to 110.49 Kb. by saving 21.33 Kb. (16.18%)]
