Old January 4th, 2019, 18:51   #16
bigb
Originally Posted by Blue_Hen_TDI View Post
Just a few things: Yes, we all have climate-controlled glove boxes standard. All S trim cars have the underseat drawer, since we don't have the additional electronics for more adjustable seats under our slightly less adjustable seats. The Hot Country HVAC setting is a software setting from the factory that can be switched on or off with VCDS. Both my Mk7s came without the setting enabled and I switched it on with VCDS. It does cool the car faster in truly hot temperatures.
OK so I have the 8Z6 Engine Cooling System: Hot Country but what is the code for the HVAC setting? I found OY4 Climatic Zones: Cold and Tropical Climatic Zones, is that it?
bigb is offline   Reply With Quote
Old January 4th, 2019, 21:16   #17
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
No: https://www.youtube.com/watch?v=Sq03Eird12E
2011 BMW 335d - JR 2.8, 600 lb/ft
Blue_Hen_TDI is offline   Reply With Quote
Old January 4th, 2019, 22:14   #18
Nuje
"For your IP address used 1 out of 3 available queries VIN / 25 queries of permanent links"
Looks like they log IP addresses - and you get 3 lookups from any one IP address.
(Hello, VPN! )
Nuje is offline   Reply With Quote
Old January 5th, 2019, 06:57   #19
bigb
hmmmm...... I wonder if that works on the manual AC cars
Old January 5th, 2019, 09:35   #20
Blue_Hen_TDI
Yes. Worked on both my S trim Mk7s.
Old January 5th, 2019, 09:47   #21
C C
TDI(s): GSW
Not necessary with old fashion knobs, you control the climate functions manually.
Automatic temperature controller is mixing heat and AC to obtain/maintain your set temperature. The "hot climate" function eliminates any heat being add to the cold air stream when the temperature sensor indicators are beyond some predefined range.
C C is offline   Reply With Quote
Old January 7th, 2019, 10:54   #22
LVPAJetta
Fuel Economy: 55/46.7/42
Default Build Sheet sticker
I was wiring up my trailer wiring, and I pulled up the rear, lower, center cover (with slot for tailgate catch) and I believe I have a build sheet sticker there...
Has anyone else found the same thing? Does anyone have a "translator" for all the options?
2003 - VR6 Clutch, PP357, RC3, IMP Boost Gauge (sold)
2015 - Sportwagen
LVPAJetta is offline   Reply With Quote
Old January 7th, 2019, 12:43   #23
RIP TDI
You will find that not all build sheet equipment shows up on the option code sticker and vice versa.
Option Code sticker codes.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old January 16th, 2019, 11:49   #24
ottomatic
Thanks for heads up . Downloaded & saved.
15 GSW SE TDI 6M Reflex Silver
ottomatic is offline   Reply With Quote
Old October 14th, 2019, 06:05   #25
Spenlowren
TDI(s): tiguan 2019
(Hello, VPN! )
Guys, for those of you who doesn't have VPN, here's a useful link with info on choosing and configuring one: free vpn for kodi
Spenlowren is offline   Reply With Quote
"BPI" solar panel installation on build sheet? 03_01_TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 May 6th, 2013 07:48
Build sheet from VIN? Lightflyer1 TDI 101 2 September 17th, 2011 19:31
Build sheet and paint codes 98 A3 12MPGHWY VW MKIII-A3/B4 TDIs 8 May 15th, 2008 05:46
Build sheet location turbofreak TDI 101 2 May 11th, 2008 19:52
Dent behind fuel door, access to sheet metal? dhdenney VW MKV-A5 Golf/Jettas 8 August 17th, 2006 13:15
Page generated in 0.19718 seconds with 11 queries
[Output: 99.22 Kb. compressed to 84.72 Kb. by saving 14.50 Kb. (14.61%)]
