Old January 1st, 2019, 18:58   #1
bigb
Default Free online access to your build sheet
I found a site where you can enter your VIN and see your build sheet. If you want to download it you have to pay otherwise you can access it free and read it online as a guest but I believe you are limited to only a few viewings.
I wanted to see if I had the auxiliary cabin heat, and I don't. I did however discover I have a drawer under the driver's seat and a 115 volt inverter in the cargo area which I hadn't noticed. I also have a :"Refrigerator: glove compartment cooling system" which I don't fully understand but I do recall seeing a dial in there with a snowflake on it, is this where I keep my lunch? I also have a "Hot Country" cooling system which is great since I live in the desert.
Anyway here is the link: https://carinfo.kiev.ua/cars/vin/volkswagen
bigb is offline   Reply With Quote
Old January 1st, 2019, 20:44   #2
RIP TDI
Great find, thanks!
9M0 - Auxiliary Heater: Without auxiliary/parking heater
7E6 - Heat accumulator system/auxiliary heater: Electric auxiliary air heater
My SE has 7E6 which I assume is cabin heater, but not 9M0.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old January 1st, 2019, 20:55   #3
Jedadiah
Jedadiah's Avatar
Pretty neat. Why would they limit viewings (or why would you pay for a pdf) when you can just copy and paste the whole thing to a word doc? Not saying I did that......
Jedadiah is offline   Reply With Quote
Old January 1st, 2019, 20:59   #4
Jedadiah
Jedadiah's Avatar
I guess 9M0 is like a Webasto heater?
Old January 2nd, 2019, 04:47   #5
BMAN
Great find Thanks...
BMAN is offline   Reply With Quote
Old January 2nd, 2019, 06:25   #6
bigb
They are hoping people will understand the costs of running a web site and will join or contribute. They probably get some revenue from the pop up ads but most people run pop up blockers now days.
Old January 2nd, 2019, 06:30   #7
bigb
Originally Posted by Chris Bell View Post
Great find, thanks!
Yeah I was checking for 7E6 and incorrectly referred to it as an auxiliary heater but it said no to that and also no to 9M0 which must be a fuel powered heater like Jedadiah said.
Old January 2nd, 2019, 07:24   #8
RIP TDI
Interestingly, my build sheet says I have 7E6, but my equipment sticker in the cargo area doesn't list it. I'm going to cross check all codes now.
- Chris
'99 BMW M3 Cabrio
Old January 2nd, 2019, 10:28   #9
mxtdiguy
Very cool, thanks for posting this !
mxtdiguy is offline   Reply With Quote
Old January 2nd, 2019, 14:34   #10
Mike in Anchorage
Mike in Anchorage's Avatar
Really handy. Thanks. I'm also going to check my wife's A*di VIN to see what surprises there are on her car as well. Happy non-orthodox new year to all.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old January 4th, 2019, 12:30   #11
ExhibitA
TDI(s): VW BUG
Thanks for the link.
ExhibitA is offline   Reply With Quote
Old January 4th, 2019, 14:16   #12
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Just a few things: Yes, we all have climate-controlled glove boxes standard. All S trim cars have the underseat drawer, since we don't have the additional electronics for more adjustable seats under our slightly less adjustable seats. The Hot Country HVAC setting is a software setting from the factory that can be switched on or off with VCDS. Both my Mk7s came without the setting enabled and I switched it on with VCDS. It does cool the car faster in truly hot temperatures.
2011 BMW 335d - JR 2.8, 600 lb/ft
Blue_Hen_TDI is offline   Reply With Quote
Old January 4th, 2019, 15:43   #13
RIP TDI
Yes, but 8Z6 is "Engine Cooling System: Hot Country".
Now, could this be something like a VCDS-selectable coolant temperature activation threshold for the sliding shroud on the variable flow water pump or something along those lines rather than a different part(s) (radiator, thermostat, water pump)? Who knows.
- Chris
'99 BMW M3 Cabrio
Old January 4th, 2019, 16:09   #14
bigb
Very interesting, I will look up mine again and see if it includes the AC and the cooling system. Really need both here.
Old January 4th, 2019, 17:57   #15
C C
TDI(s): GSW
Perhaps a ROW option such as an electric block heater.
C C is offline   Reply With Quote
"BPI" solar panel installation on build sheet? 03_01_TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 May 6th, 2013 07:48
Build sheet from VIN? Lightflyer1 TDI 101 2 September 17th, 2011 19:31
Build sheet and paint codes 98 A3 12MPGHWY VW MKIII-A3/B4 TDIs 8 May 15th, 2008 05:46
Build sheet location turbofreak TDI 101 2 May 11th, 2008 19:52
Dent behind fuel door, access to sheet metal? dhdenney VW MKV-A5 Golf/Jettas 8 August 17th, 2006 13:15
Page generated in 0.17999 seconds with 11 queries
[Output: 126.50 Kb. compressed to 105.59 Kb. by saving 20.91 Kb. (16.53%)]
