Old July 27th, 2018, 07:36   #46
Lightflyer1
Lightflyer1's Avatar
If you are a registered owner of VCDS you should just call RT and ask.
Old July 30th, 2018, 07:37   #47
740GLE
Also the ABS controller of a Mk6 jetta may not be the same as the MQB based ones of the TDI and TSI Golfs. You may be SOL.
I still need to steel the wife's car for a day and verify if I can change the setting on her Passat.
Old October 25th, 2018, 11:21   #48
adjat84th
adjat84th's Avatar
Originally Posted by Grigg3 View Post
I believe the TDIs have different bleeder valves where the diaphragm is not removable. It looks different on the inside in comparison to what is shown in the writeups. I couldn't figure it out without attempting to break it. You could drill it out larger pretty easily though.
I spent a little money and got the ECS bleed block that uses a speed bleeder. It took so little time to bleed that thing compared to before! I also changed to a different clutch at the same time, so cannot really compare the feel accurately.
The delay valve IMO needs to go if you're thinking of upgrading the clutch or if you're tuned. There were a handful of times when driving spiritedly that I would have my foot off the clutch pedal from a quick engagement, yet the revs would not come down immediately as if the disc was slipping while the pressure plate was being "delayed" from full engagement.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old December 25th, 2018, 13:40   #49
PHAT-DUB
PHAT-DUB's Avatar
can you post some pics of the OEM bleeder valve just to compare to the one in the HOW TO for the GTI.
www.badgeskins.com
Custom MK4 widebody for sale - here
PHAT-DUB is offline   Reply With Quote
Old December 28th, 2018, 10:23   #50
adjat84th
adjat84th's Avatar
Part # 1K0721468C
Sent from my Pixel 2 using Tapatalk
Old December 28th, 2018, 13:42   #51
NYTDI
Question
Originally Posted by Smokinram View Post
Thank You for the reply. That is what I was afraid of. I've searched high and low all over the place and can't find the code. The search continues...
Thanks,
Did the search ever return an answer / solution?
NYTDI is offline   Reply With Quote
Old January 4th, 2019, 15:17   #52
hooville
hooville's Avatar
Fuel Economy: 43.2 lifetime average!
Default MK7 VCDS Security Codes
I wish I could remember where I found this so I could give them credit for compiling this list!
Control Module
Security Code
Contributor
Comments
01 -Engine
27971
02-Auto Trans
2b-Steer. Col. Lock
20103
03- ABS Brakes
25004
11966
15081
18573
20103
24435
25004
28183
31857
37202
40168
44595
10505
zloybob
zloybob and
acr2001 (RT forum)
Morde
Brake booster adaptation only
DV52 comment:
40168 & 20103 - often quoted for 03, but hasn't worked for me
28183 & 44595 - also hasn't work
3C-Lane Change
05 - ACC/Start Auth.
20103
08-Auto HVAC
09-Cent. Elect.
31347
10-Park/Steer Assist
71679
20103
13- Auto Dist. Reg (ACC)
14117
Morde
15-Airbags
16-Steering wheel
17-Instruments
20103
25327
Zloybob
Not applicable to MY16 models
Accepted on MY16, but no access to adaptation channels
19-CAN Gateway
20103
32-Differential Locks
42-Door Elect, Driver
20103
44-Steering Assist
19249
52-Door Elect, Pass.
20103
55-Headlight Range
20103
5F-Information Electr.
20103
A5-Frt Sens. Drv. Assist
20103
A9-Struct. Borne Sound
6D
12345
Morde
75-Telematics
20103
Chillout
White 2015 Sportwagen S TDI - No Mods...yet!
White 2016 GTI S - A few OEM Mods so far...
Silver 2000 Golf GLS TDI - CAT 2µ Filter, Shine Real Street Suspension, Bilsteins, RC3, Nozzles
hooville is offline   Reply With Quote
Old January 4th, 2019, 21:21   #53
PHAT-DUB
PHAT-DUB's Avatar
thanks for the pic but ended doing the same as you I ordered the ECS bleeder .
https://www.instagram.com/p/Br1I1aNjJvH/
Part # 1K0721468C
www.badgeskins.com
Old February 22nd, 2019, 18:48   #54
sapgar
On the TDI there are only:
Normal, Strong, and Maximum choices
I did change the throttle response and noticed a bit better response around town.
I had a local diesel shop change the throttle setting and change the vibration reduction from “Strong” to “Normal”.... I’m going to try that out for the weekend. The throttle is smoother and more predictable, and it seems like there’s a little less torque lag. Want to see how happy I am with that before flashing the ECU. I was able to drive Kerma’s MK7 development car with 6MT and the tune and a larger turbo. That was fun!
Mine is DSG
sapgar is offline   Reply With Quote
Old February 22nd, 2019, 19:03   #55
adjat84th
adjat84th's Avatar
Mine is DSG
Nice, I'm up the road in Frisco. Have always wanted to stop by their place.
Old July 7th, 2019, 19:18   #56
Nuje
2014 JSW is not a Mk7, but rather, a completely different platform.
I don't even know that this mod would work on it.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Old July 8th, 2019, 10:01   #57
Lightflyer1
Right in the title: MK7 - DIY thread. Easy to make an error though. We all do it sometimes. Just like posting to long dead threads.
Old July 11th, 2019, 15:16   #58
Nuje
Feel free to add the Active Info Display / Virtual Cockpit retrofit to the top post.
LIFTING a mk7 TDI Sportwagen thread mxtdiguy VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 6 October 30th, 2017 17:39
Comprehensive con-rod DIY R/R thread DieselDork VW MKIV-A4 TDIs (VE and PD) 0 September 8th, 2015 11:12
Thread with diy for turbo braided oil line? witchcraftz TDI Power Enhancements 9 August 4th, 2013 00:41
IP Install DIY Thread? sackman VW MKIV-A4 TDIs (VE and PD) 7 December 22nd, 2011 14:27
Underseat Drawer Help Diy Thread 40X40 VW MKV-A5 Golf/Jettas 16 June 9th, 2006 18:42
Page generated in 0.21338 seconds with 11 queries
[Output: 128.68 Kb. compressed to 109.51 Kb. by saving 19.17 Kb. (14.90%)]
