Old August 9th, 2019, 05:46   #61
Spipa
TDI(s): Mk 7 GTD
Hi Schultze,
So how many km have you driven now after replacing the heater core? And still no coolant boil out? And how severe is the coolant loss?
How often did the boil outs happen before you replaced the heater core?
Spipa is offline   Reply With Quote
Old August 10th, 2019, 01:40   #62
mm-rocco
TDI(s): MK7 GTD 2016
Originally Posted by Spipa View Post
Hi Schultze,
This info would narrow the search for a long term solution, i am so fed up with this problem !
mm-rocco is offline   Reply With Quote
Old August 10th, 2019, 01:43   #63
mm-rocco
Can any of you allready confirm that the blow out of coolant only accurs just after the DPF ???
Old August 10th, 2019, 02:49   #64
Spipa
TDI(s): Mk 7 GTD
I am 99% sure that is the case. Since the coolant overflow only happens to me after a dpf regen during highway journeys. I never experienced a coolant boil out without the dpf regenerating the night before.
If you think about it, have you ever had a coolant boil out after just city driving? Or like me, only after highway trips?
Old August 10th, 2019, 03:08   #65
mm-rocco
@Spipa Only motorways......on citydrives or short drives the engine will not be warm enough to do a full DPF-cycle.....
Old August 10th, 2019, 03:13   #66
mm-rocco
If you have a Blue Tooth CANBUS connector laying around you can use the free version of the VAG DPF app. I have been monitoring over 3000 kilomters now and i am convinced the the both are related...
Old August 10th, 2019, 03:15   #67
Spipa
TDI(s): Mk 7 GTD
So that supports the theory of the dpf regens being the cause of the problems. During city driving (even with engine getting hot) and higway trips without a dpf regen, everything is just fine for me. If we just could legally remove the dpf..
Old August 10th, 2019, 03:20   #68
mm-rocco
I think it is the clogging up of the heater core, heater matrix which is just behind the Partikel Filter. After the DPF proces extrem hot air is blown against the heater core, as there is no circulation cause of the clogging this could cause the certain blown out of coolant.
Removing the DPF is not an option for us
I hope Schultze can backup the theory by confirming his problem is gone after replacing the heater core AND he can confirm that his blow out of coolant problem was related to DPF as well.......of that is the case the solution would be nearby
Old August 10th, 2019, 03:31   #69
Spipa
TDI(s): Mk 7 GTD
I hope that you are right, I just find it strange that the heating works completely fine when the dpf is not regenerating. If the heater core indeed is clogged, wouldn’t the heating be affected all the time? Not just during regen? My knowledge of cars is very limited but it doesn’t seem logical to me. I am waiting for my next regen to check the if the heating shows weird symptoms for me.
Old August 10th, 2019, 03:35   #70
mm-rocco
I am not a mechanic either, i did a lot of reading about his problem and the heater core and DPF seems to be related. We will see what Schultze thinks after replacing the heater core.
Old August 10th, 2019, 03:41   #71
mm-rocco
@Spipa Is you car still under warranty ??
Old August 10th, 2019, 03:43   #72
Spipa
TDI(s): Mk 7 GTD
Unfortunately not
Old August 10th, 2019, 03:53   #73
mm-rocco
Last weekend i did a test with the heating. Just after the DPF-proces i turned on the heating to max and drove for about 10 minutes then i stopped and checked the engine bay, coolant reservoir. The coolant in the reservoir raise almost near the top far above mex but did not blow out. Hopefully this information helps with solving the puzzle..
Old August 10th, 2019, 04:05   #74
Spipa
TDI(s): Mk 7 GTD
Did your heating show anything weird or no difference compared to normal? And did you put on the heating during the regen or right after it finished?
Old August 10th, 2019, 04:07   #75
mm-rocco
Just after REGEN and the heating was warm but no extreme heat...
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Coolant Expansion Tank Kray-Z VW MKIII-A3/B4 TDIs 4 January 11th, 2011 08:15
Coolant Expansion Jug Cap wny_pat VW MKIV-A4 TDIs (VE and PD) 2 June 10th, 2006 09:36
Dirt in coolant expansion tank? Diesel Addict TDI 101 54 May 22nd, 2006 01:13
Coolant expansion reservoir.. silverbeast VW MKIV-A4 TDIs (VE and PD) 6 September 29th, 2005 12:39
coolant leak from expansion tank? Platinumbird30 TDI 101 4 January 27th, 2004 17:02
Page generated in 0.16314 seconds with 11 queries
[Output: 128.89 Kb. compressed to 108.08 Kb. by saving 20.81 Kb. (16.14%)]
