Old July 18th, 2017, 22:30   #1
MIXMAN3113
Default Need advice on springs - Mk7 Golf TDI SEL
So I purchased a stop sale 2015 Golf TDI SEL, and I would like to lower it a bit. There is so much different info on springs, and I'm not really sure which is the best way to go at this point.
What do you guys recommend?
I want the ride to be comfortable as its my DD with a 70 mile roundtrip commute, but it also needs to handle better and look good without affecting the factory warranty. Right now I have 18" Austins on the car and have a 2.5 inch front gap and a 3 inch rear gap, I would like to lower it quite a bit, but not so low that it rubs when I haul equipment in the hatch.
Any suggestions??
MIXMAN3113 is offline   Reply With Quote
Old July 19th, 2017, 05:35   #2
740GLE
I'd look into H&R sport springs, drops about 1" or so, they can be had pretty cheap too, $200 or so?
740GLE is online now   Reply With Quote
Old July 19th, 2017, 13:42   #3
MIXMAN3113
Thanks, they are on the list, amongst others...like I said there is a lot of conflicting info regarding springs for the Golf TDI.... I think I may want to go lower than an inch, with the Austins being partly black, it makes the wheel gap look atrocious.
I would love to see what other mk7 Golf owners are using as springs.
Old July 21st, 2017, 06:44   #4
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Any suggestions??
Avoid speed bumps
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old July 21st, 2017, 10:56   #5
740GLE
Vortex is the holy grail of lowering spring information, they have reviews all the different makes of springs and drops, from mild to wild.
From what I've read if you're going over 1" in drop, be prepared to replace the struts not to much longer down the road.
Old July 23rd, 2017, 07:37   #6
adjat84th
adjat84th's Avatar
The lower you go, the stiffer it will be. If you really want to maintain comfort, I'd suggest the VW Driver Gear springs. They will not lower it as much as you think you want, but will maintain comfort and use of stock struts. The H&R, VWR, and pretty much anything else is going to drop you a minimum 1.3". The other thread for "Lowering Springs" shows a picture of my car and I'm pretty sure the front is lower than 1.3" drop. I tried just the springs on stock struts and hated every minute of it. Replaced with Bilstein B8s and have been so much better. With 225/40 tires at 38psi, it still hits a few bumps just wrong and creates a light jolt but they're great on everything else.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old July 25th, 2017, 05:34   #7
MIXMAN3113
Thank you for this post. Thats a nice looking car you have, love the drop! Still undecided, with a "new" old 2015 Golf with only 6000 miles, I don't think I want to replace shocks/ struts just yet. I may look into the DG springs more, Ive spent enough on parts in the last 3 months already, haha.
Old July 25th, 2017, 09:00   #8
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
The Vortex thread def has the most info and options but not a ton of those guys have TDI which means they have more options because they aren't dealing with the torsion beam rear end. After many hours of research between this and the other sites, I'm going to pull the trigger on H&R Sports for a modest drop to put it about where my 09 Jetta TDI sat. H&R has updated their set a couple times from what I can gather and the TDI specific springs will provide an even drop rather than the reversed rake drop that was being seen by kits that "would" fit but were designed for other Golf variants.
As for replacement of struts, I'd say it will depend on your roads and your driving. Our roads are pretty decent and I spent a good amount of time on the interstate and my 09 TDI struts/shocks were still working fine at 223k miles (as where my original front brake pads. :-D).
Mrrogers1 is offline   Reply With Quote
Old July 25th, 2017, 20:10   #9
MIXMAN3113
Yeah that seems to be the problem, finding info on our TDI's. Does using any springs other than VW void warranty on suspension? Thats what I want to avoid.
Ideally I want a 36mm drop in the front and 48mm in the rear, that would give me an inch of wheel gap in front and rear. Not sure the best setup for that, should I go any lower? I have dealer low profile tires that came with the car on now and will be putting on 17 inch winter tires in a few months.
Old July 25th, 2017, 21:18   #10
Mrrogers1
I'm not 100% sure on the Golf, will start poking around BUT I know these are the correct springs for the 2015 Golf SportWagen TDI >>> https://www.ecstuning.com/b-h-and-r-...-set/54788~hr/ and you can reference H&R directly here >>> http://www.hrsprings.com/application.../38/1758/2015/
H&R lists this set for your car >>> https://www.ecstuning.com/b-h-and-r-...set/547862~hr/ >>> http://www.hrsprings.com/application.../38/1731/2015/
Old July 25th, 2017, 22:37   #11
nayr
nayr's Avatar
TDI(s): 2014 Audi Q7
What about a set of springs off a GTI if your wanting to keep it OEM w/good look and daily use?
Dieselgeek dont make a MK7 skidplate yet, I wouldent go too low with a taller Diesel engine.. even on GTI Springs your oil pan will be lower than a GTI.
2014 Audi Q7 Prestige, Air Suspension, 30in BFG All Terrains on 17in Wheels - #dieselgate upgrade
2013 Golf 6MT 5 Door, Tech Pkg, Malone Stg2, Westfallia Hitch, Frost Heater, Escort Passport, Tow Bags, Runflats - (RIP: March 2013 - April 2017)
1975 Westfallia 4MT - ALH Conversion in progress.
nayr is offline   Reply With Quote
Old July 26th, 2017, 06:13   #12
740GLE
GTI would prob be too much sag.
Take a look at the Golf R variant (golf R wagen from Europe) if you want to stick to OEM.
EVo makes a skid plate, theres a thread on it not to long ago.
Old July 26th, 2017, 06:53   #13
davidch
TDI(s): None
Canadian Highline TDI (aka SEL) in hatch version come with OEM sport springs that lower vehicle ~ 1/2 in (12-13mm) and provide better handling... but I have been unable to locate part numbers... the GTI and R rear springs will not match since those have different rear suspension that US TDI
davidch is offline   Reply With Quote
Old July 26th, 2017, 08:45   #14
turbobrick240
turbobrick240's Avatar
I think the front springs/struts from the gti would work well on a golf tdi. The two cars have nearly identical curb weight. Obviously the rear suspension is different.
Old July 26th, 2017, 10:53   #15
740GLE
ahh I miss read the OP and was thinking he was looking for springs for a wagen
Need help Purchase Mk7 golf SEL or Jetta S sail538 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 9 July 2nd, 2017 04:37
H&R springs for MK7 Sportwagen TDI Ruso Turisto VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 93 December 12th, 2016 19:49
FS: VWR Springs for Mk7 Golf TDI quattrothatcould Private TDI Items for Sale/Wanted 1 August 27th, 2016 07:51
Page generated in 0.18177 seconds with 11 queries
[Output: 132.28 Kb. compressed to 111.03 Kb. by saving 21.25 Kb. (16.07%)]
