Old June 19th, 2017, 14:04   #61
Ooga
Originally Posted by Mama Roneck View Post
Update: Took my "new" 2015 GSW in for the 1,000 mile check-up on Saturday and the dealer recharged and tested the system. It seemed better yesterday in our humid 85 degree weather. Hopefully that's fixed it! I'll know for sure in mid-August.
I would push for them to replace some seals or I mean at least find the source of the leak. A/C refrigerant does not "run out" and the only way for the system to be undercharged is if it has a leak or wasn't ever properly charged. They can test for leaks. If they don't find any I would ask them to put the system under a vacuum and see if it holds. It is super common however for the leak to be coming from the compressor. The shaft seals are the major leak point but it was to my understanding that it wouldn't happen so soon. Shrader valves can give you some headache also.
Ooga is offline   Reply With Quote
Old June 19th, 2017, 14:37   #62
Funguy
Fuel Economy: 47 mpg
You really learned your stuff Ooga!
Funguy is offline   Reply With Quote
Old June 19th, 2017, 18:15   #63
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Shrader values?
Is that the devise in the tire stem?
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old June 19th, 2017, 19:43   #64
Bob S.
Originally Posted by 2015vwgolfdiesel View Post
Shrader values?
Similar type used in AC systems for gage connections.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old June 20th, 2017, 05:54   #65
2015vwgolfdiesel
Bob S
Old June 21st, 2017, 11:38   #66
Funguy
Well Dad has not found his A/C to be any colder after the service by the dealer. He got around 48 degrees from the center vents with about 80 degrees outside.
Old June 21st, 2017, 12:16   #67
Good Ol' Boy
VeeDubTDI's Avatar
With recirculate on or off?
At idle or traveling down the highway at 2000 RPM? Engine speed and airflow over the condenser both make a big difference.
If it's at idle with the recirculate off, 48 degrees is pretty good.
Old June 21st, 2017, 12:47   #68
Funguy
He started out driving, outside 80 degrees a/c 48 recirculate on
Driving down the highway temp outside went to 82 a/c 50 degrees recirculate on
On the way home on the hwy still a/c 50 degrees sometimes fresh air, sometimes recirculate
On a side note my wife (who doesn't like the heat) came home yesterday with her GSW and she was NOT happy with the A/C in her car either.
Old June 21st, 2017, 13:49   #69
I just had my A/C refreshed in my '02 because that's what it was blowing. My GSW is much colder than that. Running the A/C on low at highway speeds last Sunday, temp outside about 80, I had to turn the thermostat up significantly because the air flow was too cold.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old June 21st, 2017, 16:04   #70
Funguy
I don't understand it. Some people are getting 32 degree air and others......
Dad just called me back to say that it's 96 degrees today and he ran down the highway and could not get the air below 50 with the recirculate button on etc.
The shop said that the refrigerant was a little low and they "fixed it" but no change. I wonder if the VCDS hot climate trick from earlier in this thread ,would make a difference or if that just affects engine cooling?
Old June 22nd, 2017, 03:56   #71
2015vwgolfdiesel
The shop said that the refrigerant was a little low and they "fixed it" but no change. .... snip....
Seems something is wrong.
Remember my car was in continuous service from 2015 July.
Yesterday I went to the store for Braums ice cream. Temp = 95-ish
Thermostat set on "cold" speed set on "low".
Too cold after 1 mile. Have to turn the speed to off. But, only for a while.
Then adjusted the thermostat to a less "cold" setting.
Old June 22nd, 2017, 13:50   #72
Good Ol' Boy
VeeDubTDI's Avatar
It's possible that the "hot climate" function is changing the discharge air temperature set point. I haven't looked into anything newer than our 2012 Passat (which has awesome air conditioning) to verify. The Passat and the Touareg will both switch between 52F discharge and 35F discharge based on what the system feels it needs to do to maintain temperature. I wish it had more steps in between, as the alternating vent temp gets annoying on long road trips.
Old June 22nd, 2017, 20:30   #73
Funguy
Dad checked some more. On the Highway the car managed to go down to 45 degrees with outside temps in the 90s. When he returned to city driving the car would produce 50 degrees only
I really need to get a vcds but I always find an excuse not to. Right now I am busy remodeling the kitchen for the boss. Since I don't know what I'm doing it is slow going. When I do get one the first thing I'd like to check is this "hot climate" thing and if it changes the discharge air temperature. Really interesting stuff VeeDub, Thanks
Old June 23rd, 2017, 04:14   #74
Ted Hurst
Ted Hurst's Avatar
TDI(s): 2015 GSW
Fuel Economy: 45
Originally Posted by Ted Hurst View Post
My brand new (old) 2015 GSW has an AC issue. On my 30 minute commute home today it didn't come on until I turned it off and turned it on in my driveway. It has a major delay if it ever decides to come on. Plus it seems pretty weak when it is on. Taking it back to the Dealership next Wednesday which is the first available. GRRRRRRRRRRRRRRRR.......
Update: It was diagnosed as needing the N280 valve replaced. Part on order and will get back today or tomorrow. The Dealer could not replicate the problem on the first day so they kept it for another day. Finally got it to intermittently go warm.
'15 White GSW 6M TDI S, 20K (New old stock)
'12 Candy White JSW 6M, 80k mi, Stock - Let VW Buyback.
'09 Reflex Silver JSW DSG, 63,500 - Rust colored coolant - Traded for above 2012 JSW
'06 Black Jetta DSG Special Edition, 138k Mi, Frost Heater, RC1+,HEX-CAN USB - Traded
Ted Hurst is offline   Reply With Quote
Old June 23rd, 2017, 08:24   #75
Funguy
Ted please let us know how replacing the N280 affects the A/C performance.
help with weak air conditioning NipseyRussell VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 April 24th, 2015 18:45
Weak Rear Air mhouck VW MKV-A5 Golf/Jettas 4 January 5th, 2015 02:06
Air Conditioner Service - Air Temperature Measurements neilcaruana VW MKIV-A4 TDIs (VE and PD) 6 April 24th, 2011 02:45
Weak Air Conditioner? wldwsel VW MKV-A5 Golf/Jettas 17 August 3rd, 2007 10:22
Air conditioner does not work on high air blower setting Wayne Boudreau TDI 101 17 July 29th, 2007 06:27
Page generated in 0.19695 seconds with 11 queries
[Output: 133.85 Kb. compressed to 112.74 Kb. by saving 21.11 Kb. (15.77%)]
