Old June 14th, 2017, 05:23   #46
740GLE
Drove the Alltrack in 95 degree temps on Monady, mixed short highway and country roads, total of 20 miles or so. With fans on 3, full AC with recirc on, never saw temps under 40 degrees with a prob in the center vents.
While it cooled the car to a tolerable level, I wouldn't have wanted to turn the fans down to 1-2 which is what I'd rather be driving around with.
I'll have to check the VCDS tweak, cheap fix if it works.
Old June 14th, 2017, 06:08   #47
Funguy
Fuel Economy: 47 mpg
SWMBO! That is why I am spending my time these days renovating the kitchen.
Funguy is offline   Reply With Quote
Old June 14th, 2017, 06:13   #48
Funguy
40 or low 40s sounds good to me. I think that Dad said his car put out air just under 50 with outside temps in the 80s. I will see what readings he gets in the next few days assuming the dealership returns his car today.
Old June 15th, 2017, 14:25   #49
Good Ol' Boy
VeeDubTDI's Avatar
For comparison, our 1991 350 SDL is designed to supply 52F air to the vents (similar to what commercial building HVAC systems will supply in cooling mode). It still cools just as well as the VWs because it supplies that temperature at a much greater airflow. The idea behind the higher supply temperature is that it isn't "too cold" on the occupant's skin, but it still provides the total cooling capacity of a system that runs less airflow and a colder supply temperature.
Old June 15th, 2017, 15:41   #50
My 1993 300D has the coldest A/C and the most volume airflow of any car I've owned, although the BMW 335d isn't too shabby either.
2002 Jetta wagon, 397K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old June 15th, 2017, 17:15   #51
Ted Hurst
Ted Hurst's Avatar
TDI(s): 2015 GSW
Fuel Economy: 45
My brand new (old) 2015 GSW has an AC issue. On my 30 minute commute home today it didn't come on until I turned it off and turned it on in my driveway. It has a major delay if it ever decides to come on. Plus it seems pretty weak when it is on. Taking it back to the Dealership next Wednesday which is the first available. GRRRRRRRRRRRRRRRR.......
'15 White GSW 6M TDI S, 20K (New old stock)
'12 Candy White JSW 6M, 80k mi, Stock - Let VW Buyback.
'09 Reflex Silver JSW DSG, 63,500 - Rust colored coolant - Traded for above 2012 JSW
'06 Black Jetta DSG Special Edition, 138k Mi, Frost Heater, RC1+,HEX-CAN USB - Traded
Ted Hurst is offline   Reply With Quote
Old June 15th, 2017, 17:18   #52
Good Ol' Boy
VeeDubTDI's Avatar
Originally Posted by Ted Hurst View Post
My brand new (old) 2015 GSW has an AC issue. On my 30 minute commute home today it didn't come on until I turned it off and turned it on in my driveway. It has a major delay if it ever decides to come on. Plus it seems pretty weak when it is on. Taking it back to the Dealership next Wednesday. This sucks because I was planning my first major road trip, with my son, in the car to Cincinnati this weekend and now I think I"m staying home. Thanks VW. Your AC sucks. :-(.
Your symptoms sound identical to what I described above as the same RCV problem VW has been plagued with for years.
Old June 15th, 2017, 20:47   #53
Funguy
Please let us all know the diagnosis.
Old June 16th, 2017, 03:05   #54
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Storing vehicles for months IS a hazard.
Part I do not understand is: We do not run the A/C for 5-7 months at a time. But nothing (generally) go bad for years.
These car were "sitting" for at most, 30 months(?)
TED, let us know what happens.
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old June 16th, 2017, 07:06   #55
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
That's why I use A/C at least once every couple of weeks in the winter, usually in the form of defrosting the windshield. Keep that compressor lubed up and exercised!
Saw something similar with my Gen4 4Runner. It was a best practice to engage 4Hi and 4Lo once a month or so as some people who went a year or more would get a stuck actuator and couldn't engage 4wd.
2011 BMW 335d - JR 2.8, 600 lb/ft
Blue_Hen_TDI is offline   Reply With Quote
Old June 16th, 2017, 07:22   #56
2015vwgolfdiesel
Yes.
Forgot to say, I too, do use the A/C in the winter (from time to time) to clear the windows.
Old June 16th, 2017, 07:26   #57
On the newer cars I think the A/C Compressor is engaged when the HVAC is on defrost and the outside temperature is above 45. So odds are it's getting use during the winter regardless.
Old June 19th, 2017, 13:49   #58
Mama Roneck
Update: Took my "new" 2015 GSW in for the 1,000 mile check-up on Saturday and the dealer recharged and tested the system. It seemed better yesterday in our humid 85 degree weather. Hopefully that's fixed it! I'll know for sure in mid-August.
Mama Roneck is offline   Reply With Quote
Old June 19th, 2017, 13:56   #59
Funguy
Good Luck. I remember the humidity over there. Hope you'll be chilled!
Old June 19th, 2017, 13:56   #60
Ooga
I enjoyed reading this thread. I just got my HVAC cert. about a month ago so my mind was enjoying the read. Bob is on point with his contributions. I bought my 15 wagen just before the emissions thing broke.... like 3 days before. As the temps rise this time around here in south Texas I have started to question the A/C a bit. However it does put out a nice temp dif. One thing that I thought about was humidity. We all have to factor that into play. I think thats what bob was getting at with all the "feels" and "seems" people said. If your like me and live in a humid ass area temp ranges will "feel" different for sure.
Ooga is offline   Reply With Quote
help with weak air conditioning NipseyRussell VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 April 24th, 2015 18:45
Weak Rear Air mhouck VW MKV-A5 Golf/Jettas 4 January 5th, 2015 02:06
Air Conditioner Service - Air Temperature Measurements neilcaruana VW MKIV-A4 TDIs (VE and PD) 6 April 24th, 2011 02:45
Weak Air Conditioner? wldwsel VW MKV-A5 Golf/Jettas 17 August 3rd, 2007 10:22
Air conditioner does not work on high air blower setting Wayne Boudreau TDI 101 17 July 29th, 2007 06:27
Page generated in 0.19991 seconds with 11 queries
[Output: 133.31 Kb. compressed to 111.81 Kb. by saving 21.50 Kb. (16.13%)]
