Old June 12th, 2017, 12:42   #16
Good Ol' Boy
VeeDubTDI's Avatar
I'm not sure if VW is still using the variable displacement air conditioning compressor that they've been using for the past ten years, but if so, the problem could be the refrigerant control valve sticking. That has been a common and ongoing issue for a while now and it's possible that it has carried forward into the 2015 model year.
Old June 12th, 2017, 12:42   #17
Funguy
Fuel Economy: 47 mpg
Originally Posted by 2015vwgolfdiesel View Post
yeah
Similar situation(s) here. I even wear gloves to protect my hands (skin)
Currantly weighing the cost vs night vision results with a tint job. If not good at night, would have to srape it off --
My wife's RAV4 is perfect, but I do not drive it. So there is no direct comparison.
They say you can put a light shade of tint on that will still block the UV and IR rays of the sun. My wife wants dark anyway despite my concerns. It might work for you though.
I am looking at Sun-Tek cpx tint. It is supposed to last longer and they say that even the lighter tints block a lot of sun. I just got a squamous cell diagnosis on my lip so I might put some of this lighter stuff on my Passat.
Funguy is offline   Reply With Quote
Old June 12th, 2017, 12:49   #18
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Originally Posted by Mama Roneck View Post
Thanks for posting this - I was about to start a similar thread! I had a 1.5 hour drive on the NY Thruway yesterday with five people in the car - 93F outside. The aircon could not keep up, although it was a bit better with the air recirculating rather than fresh air coming in. My GSW has been sitting 2 years - I've had it 4 weeks with about 1,000 miles so far. I'm bringing it in for 1,000 mile check up next weekend and will ask them to check refrigerant level.
My empathy for you guys.
Beginning to believe the "2 year" storage is going to affect more than a few units.
Let us know what happens
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old June 12th, 2017, 13:36   #19
This would explain why some people have issues and others don't. I've only used the A/C in my '15 once, but it seemed to work fine. I wonder if some refrigerant lubricant would help.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old June 12th, 2017, 14:58   #20
Bob S.
In reading this thread, I find that it is rather subjective: "Weak", "Feels", etc. and different climate/humidity conditions. Previously, mine "felt" "fine".
In an attempt to quantify, I went out and started my '15, it had been sitting in the shade for a couple days, using a Ratek surface reading probe, outside car temp. surface, black dash surface & interior seat surface all had readings of 86F to 87F. Engine started, engine at idle, AC then turned on ,external air source (not recirculating), fan on high, outlets in vent only position, w/ all vents open, the reading inside the center duct as viewed read through the open vent:
- The initial out coming air temp was 86F (consistent with the air in the system.
- The temp started decreasing quickly, within a minute, out coming air was in the low 60'ds F.
- In under 2 minutes the duct/outcoming air temp was 55F.
- I then rechecked the dash surface & seat surface, they decreased to 1 deg to 85/86F. The interior had cooled 1F.
It strikes me that -30 F temp differential with the system running at idle in less than 2 min is pretty darn good! I was amazed that it was that much. Now I know why it "felt fine".
VeeDub & IBW may be on to something.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old June 12th, 2017, 16:25   #21
2015vwgolfdiesel
Bob S.
Nice observation(s)
Old June 12th, 2017, 16:26   #22
Funguy
Wow Bob, that is what I like about this forum. Lots of serious thinkers.
It would help to know just what the temperature coming out of the vents is supposed to be according to the design of the car. I'm not sure that 55 degrees is cold as it should be.
I was thinking also that our information (aside from yours) is subjective. One person's comfort is another persons torture.
Old June 12th, 2017, 18:31   #23
Bob, although those sound like good results, MKIV cars do better. I just picked up my wagon after having the expansion valve, receiver/drier, and compressor replaced, as it wasn't blowing air as cold as I have come to expect. With the fan on high and the A/C on recirc (I think), Mr. Chill (see what I did there) saw 32 degrees F at the vents. MKIV cars with good A/C will fog the windows on a hot day.
Old June 12th, 2017, 18:52   #24
Bob S.
Typically, it is the temperature differential of the air being cooled. Temp of ingoing air vs outgoing air. i.e., how much is the air being cooler that passed over the evaporator? To me 30 deg drop is better than I expected.
That said, I am impressed by Peter's MKIV drop above, I would expect nothing less then perfection from Mr. Chill (Pun intended).
I will recheck with the air set in the in recirculation mode.
Old June 12th, 2017, 20:12   #25
Funguy
Wow, 32 degrees!! I remember my sister's 78 honda civic would freeze up (literally a block of ice) if you set the compressor too cold! I liked that you could could actually adjust the compressor on those cars rather than now where the compressor cycles don't change and you have to introduce HEATED air if you are too cold. Seems wasteful. I end up doing what the previous poster said, turning the a/c on and off if it is too cold
Old June 12th, 2017, 22:38   #26
Mr_robs
TDI(s): 15' GSW
I will agree with someone elses statement that the AC is definitely weaker at idle. I was sitting in traffic one day with the fan on 4, windows up, lowest temp & i have 22% tint. Felt like the vents were blowing out luke warm air. Started moving then i could feel the temp drop.
Not surprised as it seems like a design "feature" with the one cooling fan, high idle in hot temps with ac on etc.
I chop it up to newer cars just having a generally "weaker" feeling ac than old ones. Drove my car to vegas and back last week. Was 105+ a couple days and i never had to max out my fan speed in the car.
TL;DR AC feel is super subjective & performance is based on many things.
Mr_robs is offline   Reply With Quote
Old June 13th, 2017, 03:32   #27
larrydk
larrydk's Avatar
TDI(s): Sportwagen
not the strongest A/C I've ever had, but gets the job done......My wife has a Subaru XV, seems a lot of new cars do not have ultra powerful A/C's these days....just a generalization.
Larry Kaufman
2015 Golf SW 6MT
larrydk is offline   Reply With Quote
Old June 13th, 2017, 04:28   #28
Growler
Got Soot Vendor
Growler's Avatar
Put me squarely in the underwhelmed camp with the AC on my new GSW. I have put almost 4000 miles on mine since I purchased and havent been too impressed with the ability of the AC to cool off the car quickly, although I do not like to turn the fan up over speed 3 or so, my mk4s never had this issue and I almost never turn the fan over setting 2 on those (no foam coming out of the vents and I think this helps FWIW)
My car seems to be one that was used more than most during its 2 year hiatus, as it had just over 1000 miles on it at pickup so it didn't sit as much as some of the others that I have read about.
Perhaps Ill get one of those vent termometers and see what is actually outputting. (any suggestions on what to use?)
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old June 13th, 2017, 05:22   #29
Brian's96TDIPASSAT
My "new" 15 Golf is not as cold as my 11 was. I think I'm going to throw my gauges on it when I get home later and see if it needs a little 134
Brian's96TDIPASSAT is offline   Reply With Quote
Old June 13th, 2017, 06:03   #30
Funguy
I think so also. Could that be because of the new refrigerants?
help with weak air conditioning NipseyRussell VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 April 24th, 2015 18:45
Weak Rear Air mhouck VW MKV-A5 Golf/Jettas 4 January 5th, 2015 02:06
Air Conditioner Service - Air Temperature Measurements neilcaruana VW MKIV-A4 TDIs (VE and PD) 6 April 24th, 2011 02:45
Weak Air Conditioner? wldwsel VW MKV-A5 Golf/Jettas 17 August 3rd, 2007 10:22
Air conditioner does not work on high air blower setting Wayne Boudreau TDI 101 17 July 29th, 2007 06:27
Page generated in 0.18500 seconds with 11 queries
[Output: 135.20 Kb. compressed to 113.75 Kb. by saving 21.45 Kb. (15.86%)]
