Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old October 19th, 2018, 10:21   #61
relumalutan
relumalutan's Avatar
262,000 miles on 2006 Jetta. Still on the original turbo, replaced camshaft and flywheel once.
relumalutan is offline   Reply With Quote
Old October 19th, 2018, 14:05   #62
mk3j
TDI(s): Mk4 PD
285k on my 2003 5spd manual.
replaced the 5th gear, clutch, egr delete, 3in turbo back straight pipe and everything else is factory for the most part save a few vacuum lines love this little wagon
mk3j is offline   Reply With Quote
Old October 19th, 2018, 18:43   #63
Gilty_one
Gilty_one's Avatar
291000km = 180820 kmiles on my 2012 Jetta TDI highline DSG - new dual mass flywheel, vacuum pump.
I'd get better mileage if I would just drive slower...
Last edited by Gilty_one; October 25th, 2018 at 20:40. Reason: (added converted miles value)
Gilty_one is offline   Reply With Quote
Old October 19th, 2018, 18:44   #64
[486]
TDI(s): 02 golf ALH
maybe 45k? Got the car with 130? on it...
across 3 engine rebuilds, 5 turbos, 2 transmissions, 3 sets of axles, 3 sets of nozzles
I'm not a good influence.
[486] is online now   Reply With Quote
Old October 20th, 2018, 01:52   #65
lovemybug
Originally Posted by lovemybug View Post
Only 279,000 miles on my car.
Updating my previous post to reflect the 361,000 miles currently on my car.
2002 Red New Beetle TDI, Manual swap with .717 5th gear. *SOLD*
Mods so far: Coolant migration mod, Ventectomy, Euro headlight switch, HID retrofit, KII VCDS cable
I can't believe how much crap I can fit in this thing.
lovemybug is offline   Reply With Quote
Old October 20th, 2018, 05:57   #66
SaxmanKana
But the fuel mileage keeps going up!
Dweisel's Diesel. Thanks for reaching out to me & selling one of the herd!🐞
SaxmanKana is offline   Reply With Quote
Old October 20th, 2018, 06:09   #67
eddieleephd
Fuel Economy: 38mix / 47@70-75
Originally Posted by SaxmanKana View Post
248K on mine, how long does the original clutch last?
Depends on how long the dual mass flywheel lasts
Sent from my Armor_2 using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old October 20th, 2018, 09:24   #68
[486]
TDI(s): 02 golf ALH
It actually did for a while, could only get 42 stock, last rebuild with the cut down pistons took a little bit of work in the timing maps to get it back up to the 48 it's been since I got the maps nailed down the first time
Old October 20th, 2018, 14:31   #69
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
I had 60k on my new purchase 09 Jetta TDI when I traded it in on my new purchase 2013 Passat TDI.
I had 60k on my 2013 Passat TDI when I traded it in towards my used 2015 Passat TDI.
My 2015 Passat TDI had 55k when I bought it and is now at 60k. Looking forward to at least 100k miles on this one.
Fixmy59bug is offline   Reply With Quote
Old October 22nd, 2018, 00:26   #70
Dan C.
29k on the '15. rest in the sig
'15 Passat SEL CPO wrnty til 8/2020
Dan C. is offline   Reply With Quote
Old October 22nd, 2018, 14:13   #71
mahir
TDI(s): 1.9TDI ALH
2001 Golf IV ALH
Buyed it with 109.361 in november last year and now it has 136.080. Dident have any problems with the engine or stuff just the turbo was bad since i had it.
mahir is offline   Reply With Quote
Old October 22nd, 2018, 16:32   #72
TDI smile
TDI smile's Avatar
Location: Edmonton, Alberta (b4 BC - LOWER MAINLAND = Chilliwack)
299,232.48 miles = 481,568 km
TDI smile is offline   Reply With Quote
Old October 22nd, 2018, 20:35   #73
Rodmiser
Fuel Economy: sorry last tank 44.2 MPG
46064 miles or 74132km
44.2 MPG or 5.2Avg L/100km, or 53 Avg UK MPG and 166.73 Last 12 Months
Total Gallons Fueled
Rodmiser is offline   Reply With Quote
Old October 25th, 2018, 20:14   #74
tdiman
tdiman's Avatar
Default how many miles have you racked up on your TDI?
Just purchased a 2015 on aug 7 sel tdi Jetta 41,160 on clock now 50,000 average mileage 39 Kerma Ecu tune and dsg tdi flash tune 8,840 miles to date around 236 gal =723 .00 not bad 65 dollars a week
tdiman is offline   Reply With Quote
Old October 26th, 2018, 07:12   #75
MPLSTDI
MPLSTDI's Avatar
TDI(s): 06 Jetta DSG
Fuel Economy: Max 54, 44 avg
I am really not racking up the miles like a used to.
200K Original Turbo, Camshaft (which looks like new!), Brakes!
2nd Flywheel (120k), Driver's door harness, Injector hardness, alternator pulley, 3rd set of tires, one front wheel bearing.
Only took me 7 years to get to 164k, I moved much closer and work from home about 50% of the time now too.
Member of the TDT for PD Mafia
2006 Jetta TDI DSG base 0 - heated seats Shadow Blue 210K ScangaugeII Hidden hitch GDE HOT/ECO Tune
MPLSTDI is offline   Reply With Quote
Tell Us About Your Running Swaps: Mileage Racked Up,Impressions,Things You Would.... G60ING TDI Conversions 66 August 4th, 2017 17:08
Highway Miles vs. City Miles/EGR System Question lawnarjax VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 April 24th, 2015 09:59
2002 Jetta TDI 5speed 230k miles Selling my 2002 TDI with 230k miles 5 SPEED manual t VDUBjettaTDI TDI Cars for Sale/Wanted 10 September 16th, 2013 15:59
2009 TDI Jetta with 6900 miles. 53.1 mpg, 2600 miles. Rod Bearing TDI Fuel Economy 4 December 15th, 2008 14:02
98 A3 Jetta with Only 9,044 miles, Yes, 9K miles. Harvieux TDI Cars for Sale/Wanted 2 March 9th, 2003 19:19
Page generated in 0.18852 seconds with 11 queries
[Output: 129.93 Kb. compressed to 108.13 Kb. by saving 21.80 Kb. (16.78%)]
