Old November 14th, 2015, 17:38   #31
Good Ol' Boy
VeeDubTDI's Avatar
I think core clogging is going to be a recurring issue unless they address the excess flux in the radiator. If enough repeats happen, expect to see a radiator replacement added to the TSB.
Old November 23rd, 2015, 13:36   #32
aclark
TDI(s): Passat B7
Started noticing yesterday when my wife was in the car that the passenger's side was blowing cooler air. Took it in today and the service guy said it wouldn't have failed at 44k miles, and that he hasn't heard of the core clogging. Called me back 4.5h later and said it was a heater core issue, and that his manager put in a goodwill request with VWoA for payment. They agreed to pay for the repair, but not for the diagnostics or flush which I think is pretty crappy considering a flush is part of the TSB and w/o diagnostics the dealer wouldn't have known (other than me telling them) that is was the heater core.
Called VWoA on my own and started an issue for the full amount. Waiting to hear back now. I guess worst case I'm out ~$250 as opposed to the $922.85 + tax, but I'd still like to be out $0 for a known issue that should have been proactively addressed by VW.
aclark is offline   Reply With Quote
Old November 24th, 2015, 16:00   #33
aclark
TDI(s): Passat B7
Quick update on mine. Got the call today that even though the dealer initiated "goodwill" payment was only good for the core itself, my call to VWoA got the whole thing paid for.
Old November 24th, 2015, 23:32   #34
jrm
Fuel Economy: 42/52
having this problem on such a new car is completely unthinkable. even my 1990 Toyota has a sparkling clean core and I didn't change the coolant for the first decade I owned it
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old November 26th, 2015, 09:48   #35
dogger37
dogger37's Avatar
TDI(s): 2012 passat
update...
I received the car back last week. This is my second heater core in the car, and VW rep claimed I was the first " repeat customer" for this issue. They did cover the entire cost ( car has 137,000) but I think that was partly because I paid the full bill the first time. The mechanic flushed the system multiple times and also used some type of acid that VW instructed him to use. They also changed the coolant to water ratio they want used in the vehicle. I will try and find out what type of acid was used along with what the new ratio is for the coolant/water mixture.
heater core used 561-819-031-B1
gasket set 561-898-380-1
coolant G-013-A8J-1G1
my first heat core replaced was a 561-819-031-B and coolant used was G-013-A8J-1G
dogger37 is offline   Reply With Quote
Old November 26th, 2015, 14:04   #36
jrm
Fuel Economy: 42/52
even vinegar is classified as a "acid" for coolant system cleaning. Used it on my iron block ram and it worked amazing.
Thanks for the part number updates, that will be very helpful for us do it yourself ers
2015 Passat TDI SEL
Old November 26th, 2015, 14:31   #37
tdiatlast
dogger37: I'm curious about the "1" after all the part numbers. Anyone know what that might designate?
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old January 5th, 2016, 12:34   #38
sdeck
sdeck's Avatar
Why can't I find this TSB online anywhere? I tried to print it from the google drive linked but it says printing is disabled by the owner.
"If you make it idiot proof, nature will build a better idiot"
Considering WVO? see these:
http://forums.tdiclub.com/showthread.php?t=213288
http://forums.tdiclub.com/showthread.php?t=249556
sdeck is offline   Reply With Quote
Old January 5th, 2016, 17:15   #39
irishrob
Fuel Economy: 35.5
I am now having the same issue with 60,000 miles on my 2013 TDI - SE. Winter has arrived in Connecticut and it is cold! I suspected it by the end of last season but didn't have time to address it as the weather was getting warmer. I called VWoA today and was given the following information:
First I was provided with a case number that I am to give to the service manager when I bring the car in. The service manager is then going to converse with Volkswagen of America and I was told that there MIGHT be some compensation. He was not definite on that but did tell me that if there is a future recall on heater core, I would get reimbursed for the full amount. I was driving at the time and did not have a chance to get this advocates name. He also said there are no service reports or recalls on this.
Just reporting what I heard. I do not have extended warranty and understood the risk before purchasing a Volkswagen but the lure of not stopping gas stations as much because of the diesel outweighed poor reliability potential.
I want a Tesla next.
irishrob is offline   Reply With Quote
Old January 5th, 2016, 17:42   #40
irishrob
Fuel Economy: 35.5
I just saw there is a service bulletin. I specifically asked if there was one and was told there was not by the advocate. It's hard for me to believe he didn't know this. What reason would they have to withhold this?
Old January 6th, 2016, 07:00   #41
tdiatlast
irishrob: I don't think anyone here would refer to any VW employee as an "advocate." They are all VWoA employees, and would only be functioning as "advocates" for VWoA, not the consumer.
As for buying a Tesla: go for it, write the big check, keep a Halon fire suppression system handy...https://www.google.com/url?sa=t&rct=...pbmzKQ6koLCxvg
Old January 6th, 2016, 08:21   #42
Ares
Originally Posted by MB2VW View Post
Having an out of warranty 2012 NMS, I'm curious why the 2012 isn't cited in the TSB.
Does VW cover out of warranty vehicles when a TSB is issued?
2015 GX 460
2014 Forester
(gone) 2013 Passat TDI SE
Ares is offline   Reply With Quote
Old January 6th, 2016, 08:48   #43
Wurster
VWOA refused to cover the cost of replacement for my 2013 because I was "too far out of warranty at 75k miles and should have brought the car in last winter when the problem first surfaced."
Many others have had success in VWOA covering the cost though.
Wurster is offline   Reply With Quote
Old January 6th, 2016, 09:26   #44
irishrob
Fuel Economy: 35.5
[QUOTE=tdiatlast;4976294]irishrob: I don't think anyone here would refer to any VW employee as an "advocate." They are all VWoA employees, and would only be functioning as "advocates" for VWoA, not the consumer.
He introduced himself as "A Consumer Support Advocate"
Old January 6th, 2016, 09:44   #45
Ares
I've had Toyota perform TSBs at no cost because they extended coverage for the issue (like 7y/75k).
If the problem is common enough to issue a TSB, VW failed to deliver a reliable part/design, and should cover the repair within a reasonable time frame.
2015 GX 460
2014 Forester
Heat Only on Driver Side - clogged heater core VTSKI VW Passat Family (NMS and B7) TDIs (2012+) 575 November 21st, 2018 16:08
Driving with clogged heater core dangerous? tjsadler VW Passat Family (NMS and B7) TDIs (2012+) 29 November 13th, 2017 15:04
Rusty coolant and clogged heater core sweetlou132 VW MKV-A5 Golf/Jettas 24 March 5th, 2017 17:13
P2457 Code - 2014 Passat TDI TDINJ VW Passat Family (NMS and B7) TDIs (2012+) 2 June 25th, 2015 06:10
'10 GOLF TDI, NO HEAT (passenger side), Driver side gets HEAT? Clogged heater core. RomanL VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 March 23rd, 2015 11:23
Page generated in 0.19920 seconds with 11 queries
[Output: 128.55 Kb. compressed to 107.47 Kb. by saving 21.09 Kb. (16.40%)]
